Sponsored by: CARiD
Quick belt question
Old Feb 19, 2012 | 01:25 PM
Duckie's Avatar
Quick belt question
Is there any break in for a new belt? Just put new alt/WP and ps belts on, so I was wondering when I should go back and re check the tension. 1986 22re FYI.
Old Feb 19, 2012 | 01:38 PM
AMSevo8man's Avatar
Its always a good idea to go back and check belt tension. After you replace it I would take it for a 10-15 minute drive then check tension. Then again after about a week. I like to check at every oil change. Better safe than sorry. Its more or less just my preference.
Old Feb 19, 2012 | 01:41 PM
rworegon's Avatar
Never hurts to check the belt tension after some miles. I tend to take a look under the hood every few weeks or so anyhow.
Old Feb 19, 2012 | 02:43 PM
James Woods's Avatar
The belt won't typically stretch that fast, so if the tension is good when you first put it on, checking it every oil change when you should be taking the time to check everything anyway, should be fine.
Old Feb 19, 2012 | 04:30 PM
Duckie's Avatar
Thanks guys! I had just put a new alt/WP belt on when I first did the timing chain job, and I started getting a non-bearing chirp after a few days, as well as I noticed that my voltage would drop at idle, but be fine at load. I knew it probably just needed to be re-tensioned, but I neglected it. This morning the belt broke on me on my way to work... lesson learned. I'll check it again in the morning before I leave to go to work, and before I head home.
jasonty
41
Dec 23, 2018 01:00 PM
WellsR
12
Jul 31, 2015 03:27 PM
TJWilly
Jul 31, 2015 02:05 PM
cgilley
Jul 25, 2015 10:55 PM
icentropy
Jul 14, 2015 10:23 AM
