Sponsored by: CARiD
Spare tire removal - seized?
Old Jan 11, 2012 | 02:17 PM
alltoyrev's Avatar
Alrighty - Thought this post belongs in the newb section...
So got a flat the other day, and tried without luck to lower my rear tire. (89 Ln106 - hilux - to my knowledge same system as my 86 xtra cab..) So I connect all the rods with the end piece being the hook that normally turns the bottle jack - fish it through the bumper (above) and into the slot. Lefty loosey but no dropping of the tire. So I pounded on the assembly from below a bit to get some of the road junk out, no avail...
any ideas on a next step? Was going to spray the whole thing down with degreaser... perhaps deflate the tire.. etc. it hands on chains connected to a spring loaded thingy.
Help please!
Old Jan 11, 2012 | 02:46 PM
snobdds's Avatar
Clean up the mechanism and spray, multiple times, with PB Blaster. If that gets you nowhere, then a grinder with a cut off wheel is about your best bet.
Old Jan 11, 2012 | 02:52 PM
GuitarMike's Avatar
Mine is frozen, like many others.
What I'm gonna do in the spring is to cut the chain, get it out of the mechanism, and keep the retainer that's on the end.
Then I'll tack weld a hook to my rear bumper or a frame rail, and run the chain to that. You could set it up to require a key (padlock) or something, for security - mainly security from falling off on the road! 2 'loops' (holes reamed in angle iron, maybe?) would let you do that pretty safely, running the chain thru and pinning with the lock....
Just something I've been thinking about; no fun keeping the spare in the tiny bed!!
Old Jan 11, 2012 | 03:00 PM
BMcEL's Avatar
OBA & tire plugs. No spare required.
Old Jan 11, 2012 | 03:11 PM
alltoyrev's Avatar
blast off!
Thanks all!!
Well I will try the pb blaster method and hope it loosens things up - I actually bent (twisted) one section of the rod trying to loosent the damn thing.. sucks this keeps me away from my valve seals this week! Figure I should get this solved before I get stuck somewhere really bad.
I'll let you know how I make out!
Old Jan 11, 2012 | 11:06 PM
wyoming9's Avatar
Red face
I have never been able to ever get one loose with the 4Runner it is strapped to the roll bar.
In the trucks I keep meaning to make a mount that it swings on in line with the side of the bed just one more project that never gets done.
Old Jan 11, 2012 | 11:14 PM
dropzone's Avatar
Fossilized
I take it you have never shredded a side wall
Old Jan 12, 2012 | 06:00 AM
Terrys87's Avatar
I have fixed two really bad tire carriers. Let it soak in PB Blaster for a couple of days. While waiting, just keep adding a little more. It will free up eventually. After getting it freed, just have to cycle it up and down several times.
Once I get it working real good, I go a couple of times a year and just had some grease to it. When you do your oil changes is a good way of remebering to do maintainace on your tire carrier.
Old Jan 12, 2012 | 06:13 AM
83's Avatar
83
Yep, I sprayed the one on my 83 with liquid wrench and white lithium grease every couple days, over the few month period that it was sitting in my garage being rebuilt. Eventually it broke free, and has worked ever since. I don't live in a very rust area, though...
Old Jan 12, 2012 | 07:32 AM
BMcEL's Avatar
Nope. I'll take my chances.
Old Jan 12, 2012 | 08:23 AM
Duckie's Avatar
I was able to get mine old spare to lower about halfway. I wound up just cutting the chain, throwing the spare tire and rim away, and have my full size 33x1250 spare in the back of the runner.
Old Sep 6, 2022 | 12:01 PM
Kevlarster's Avatar
I just joined this site for the same problem. I have been spraying PB and banging on what I can. I also bent my hook rod assembly trying to lower it. There is no direct access to the winch but I may end up cutting off the retaining piece at the bottom of the chain if it doesn't break loose soon. Thanks for all the advice up there.
Old Dec 5, 2022 | 01:18 AM
mydanielcreg_3's Avatar
874runnersr5
Nov 4, 2008 08:55 PM
keithguts
Oct 18, 2008 05:25 PM
toyota884runner
Dec 1, 2006 11:43 AM
Cardiac
13
Nov 23, 2005 04:43 PM
JGage
Aug 21, 2003 07:26 PM
