Sponsored by: CARiD
3vze Dash Pot Cracked
Old Feb 4, 2012 | 11:46 AM
ksti's Avatar
Unhappy 3vze Dash Pot Cracked
So last Saturday I cleaned my throttle body and all was good. I drove it around on and off that day, no problems. So a week later today I know have a high idle when warmed up.
Idles fluxuates between 1250 & 1700 so I checked first thing for vacumn leaks, didn't find any Tried to adjust idle and screw is now turned all the way in.So reading other threads and FSM I checked the Dash Pot and pulled cover off and its cracked pretty good.
Could this be the reason for high idle? Im kinda lost as all I did was just clean throttle body. Any help is always appreciated. Thanks
Old Feb 4, 2012 | 12:02 PM
MudHippy's Avatar
Remove the idle speed adjusting screw. Then remove the o-ring from it. Replace the o-ring. Then replace the idle speed adjusting screw. Then re-adjust the idle speed.
No, it's not the dashpot, unless it's holding the throttle open when it shouldn't be. Which you could check by manually closing the throttle(over-riding the dashpot if it's pushing on it) at idle and seeing if it's being held open by it. It should be closed all the way/pushing it closed shouldn't be possible.
Old Feb 4, 2012 | 12:06 PM
ksti's Avatar
Okay, I going to do it right now, thanks for helping again MudHippy. Ill let you know.
Old Feb 4, 2012 | 12:13 PM
ksti's Avatar
I Pulled out the Idle screw and its real dirty guess I didn't do such a good job cleaning throttle body. Anyway off to get an o-ring.
Old Feb 4, 2012 | 04:51 PM
ksti's Avatar
Well I replaced o-ring on idle adj screw and set idle, problem solved idles between 800 & 900. Just for kicks I stoped by my local toyota dealer to see if they had o-ring. He said they dont even sell a new idle adj screw. You have to buy a new throttle body assembly.
I laughed and left. Wow I spent thirty cents at my local auto parts store. Fixed! Thanks for the help I really appreciate it.
Old Feb 4, 2012 | 08:10 PM
MudHippy's Avatar
You bet. I'm glad that worked for ya.
rednecktoyotahunter
Nov 18, 2015 08:58 AM
PETDOC
Aug 18, 2015 05:29 AM
ViperTT
Aug 14, 2015 05:27 AM
britishdudes2dr
Jul 25, 2015 06:47 AM
smiley52
Jul 11, 2015 05:16 AM
