Sponsored by: CARiD
Getting a lux soon just need to no some stuff
Old Jan 28, 2012 | 11:40 PM
Gilly2011's Avatar
hey guys im getting a 1985 soon and just needed to no some stuff
1. i got some 35s on 15inch rims and was wondering what diff gearing would be needed
2. what Chevy springs do you use or whats the best year model ones to use
3. it looks like it has a lift kit in it but he doesn't no what no one it is how could i find out?
4. are rancho shocks good for general rock crawling
5. buy or make my own shackles
6. if i were to change the engine out and i was going to put a Holden commadore engine in should i use the auto transmission or use the hilux one and are stronger cvs needed atm or only later on im only going to do abit or rock crawling
im sure i will think of more
Old Jan 29, 2012 | 08:50 AM
creswellhick's Avatar
ranchos suck only good for mudders 529s for gears and a 85 is a solid axel so it dont have cvs use google it works pretty good
Old Jan 30, 2012 | 05:05 AM
Boomtacoma01's Avatar
Wrong place for this
Old Jan 30, 2012 | 05:40 AM
rattlewagon's Avatar
Newbie tech is the perfect place for this.
OP: with 35s, youll want 5.29s
Your looking for any 63 inch chevy spring. Used on most half tons from the 90s through the mid 2000s.
Look for any marking or numbers on the springs to try and identify them.
What are you trying to achieve out of the shackle? Lift? What wrong with the ones that are on there.
If you leave the front diff open the stock shafts will hold for a while. But if you lock it, be ready to buy some Dirty 30s or Longfields.
No Idea on the engine swap, we dont have holdens over here.
Might also want to look into a IFS steering box and Histeer.
Welcome to the forum!
Old Jan 31, 2012 | 08:21 PM
Gilly2011's Avatar
thanks mate i forgot about the steering box and if it take some leafs out of the ones that are on it at the moment that should make it flex heaps better shouldn't it? and do you think i should put some diff braces on? and do the shackles make for flex or more hight?
Old Jan 31, 2012 | 08:41 PM
igotit's Avatar
if memory serves me correctly........the holden commodore is a 4 dr version of our gto....6.0 liter i think.
its a super charged family car.
the stock toyota tranny wont last long.
Old Jan 31, 2012 | 09:30 PM
ThatGuy1295's Avatar
thats a big list.......
I can offer this
Gearing calc:
http://www.grimmjeeper.com/gears.html
Old Jan 31, 2012 | 09:32 PM
Gilly2011's Avatar
nah the tranny will hold up i have a mate that did a conversion and its held up fine
Old Feb 4, 2012 | 09:16 PM
Gilly2011's Avatar
if i put 35s on do i have to do the gears straight away? or can i do then when ever?
Old Feb 4, 2012 | 09:28 PM
yotaman85's Avatar
answers in red...
5.29's would be good
90's 2WD springs will work.
dont know... sorry.
rancho's will be fine.
up to you, if you can make them all the same and get ahould of good meterial your golden.
6. if i were to change the engine out and i was going to put a Holden commadore engine in should i use the auto transmission or use the hilux one and are stronger cvs needed atm or only later on im only going to do abit or rock crawling.
up to you. if you use the GM tranny the 5.29 gears might need changed.
when you do let us know..
Old Feb 4, 2012 | 09:29 PM
yotaman85's Avatar
in all my experiance.. lower gears are one of the first things i would want. so yes, as soon as possible.
Old Feb 4, 2012 | 10:03 PM
Gilly2011's Avatar
yer im just going to make my own it wont cost much and if it is the stock leaves if i take 2 or 3 leafs out of the pack will it make it flex better?
Old Feb 5, 2012 | 04:08 AM
In theory, it will flex better. But will also be more prone to bent leaves, and might cause the truck to sit lower.
Might want to look into different shackles.
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
moparbay
Oct 6, 2015 09:24 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
