Sponsored by: CARiD
Coolant leak causing idle problems?
Old Feb 1, 2012 | 08:08 PM
blackdog314's Avatar
Question Coolant leak causing idle problems?
I have an 86 22re 4runner that has a bad (getting worse) miss at idle that goes away at higher rpm. I have changed the plugs, wires, rotor, cap and coil. I am going to check the vacuum lines, egr, o2, maf, and tps as soon as I get time. My symptoms sound like several that have been solved by replacing or repairing one of those, but while I was searching here I found a few links that say that coolant problems can be a cause too. I have a couple of coolant line leaks so could these be causing air in the lines/bad readings that will cause these problems? It has never overheated and there is no coolant in my oil or vice versa I just have to top it off every now and then. Thanks in advance for any help.
Old Feb 1, 2012 | 08:17 PM
E-ROC's Avatar
Checked your timing and the bolt that holds the distributor from turning? Hows your timing chain? Edit: and your fuel filter and fuel pressure?
Old Feb 1, 2012 | 08:30 PM
Replacing the fuel filter tomorrow and I will make sure to check the distributor bolt when I do that. The fuel pressure check and timing check are on the list too just forgot to put them in the original post. For that matter I am going to go through the efi system and do the code check procedure that is described in the fsm. This is all new to me so I wanted too make sure I am not missing anything hence the coolant question.
Old Feb 1, 2012 | 08:44 PM
E-ROC's Avatar
At least you know what a FSM is and how to use it. Your a step ahead already! Good luck.
Old Feb 1, 2012 | 08:56 PM
Thanks I was lucky that the previous owner had a fsm and included it in the sale along with most of the gaskets and seals that needed to be replaced. It seems like I have read the whole thing in the last three months. With that said is there any truth to cooling system issues causing similar symptoms or am I just chasing my tail there?
Old Feb 1, 2012 | 09:11 PM
E-ROC's Avatar
That is a question i truly cant answer due to the fact that i have not experience it myself yet nor have i read anything about it. Hopefully someone can chime in with some good help in that department.
Old Feb 1, 2012 | 09:15 PM
TylerH's Avatar
I believe i am having the same symptons. And im 99% sure its caused from coolant. Your truck gets air pockets and dosent read the corect temps. So its stays in its closed loop.
Old Feb 1, 2012 | 09:17 PM
Thanks for the quick responses anyway and anyone else that has any knowledge or even a link it would be greatly appreciated.
Old Feb 1, 2012 | 09:24 PM
Just saw your post Tyler and that's what I was getting at. Do you know what sensors cause that? Mine also hasn't been idling up on cold start since the stumble got worse which I assume is related but I'm not sure where that points me.
Old Feb 2, 2012 | 08:05 AM
anyone else got any insight?
Old Feb 2, 2012 | 08:20 PM
TylerH's Avatar
I think your IACV has the biggest role in the idle problems. What i think in mine is the air bubble/s go to the highest point which is the IACV and starve it from coolant. So that makes it idle wierd. Mine leaks about a quart of water a week. Mine will act really wierd when its hot. If i start it it will try to die i have to feather it for about twenty seconds. I believe when im feather it that just moving coolant around and moving the air bubble.
Old Feb 3, 2012 | 06:43 AM
Sounds like what I have going on too gonna add the IACV to my list.
Charecter1
Nov 6, 2023 10:08 AM
Colington
Mar 8, 2020 09:51 AM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
