Rear axle
Rear axle
i drive a 1984 pickup 4x4 im rebuilding fully im putting in a chevy v8 305 or 350 if i bore it out but i still have my stock 4 cylinder rear end and transmission i want to replace the transmission with an automatic one and want to get a bigger rear end to hold up to the new motor what other trucks tranmission/rear axle can go under the truck and work ive been told that an axle/transmission from a jeep or chevy s10 would work is this true if not what could i get to swap it with thanks for the replies
If you want auto trans keep it GM. Like a TH400, TH350 etc etc. IMO the gear driven Toyota t-cases are pretty stout. Hopefully someone can confirm that. However, might be cheaper to just match a GM case to the trans. As the advance adapter adapters can be a bit pricey.
Don't know much about the axles but if it were me I'd be going with a dana60s and wouldn't look back. Question is width wise what would work. Either way, better know how to weld. Because nothing is going to be a bolt on swap other then the engine stuff.
^^True, that would be sweet, but also expensive.
I think youll be fine with the stock rear end. They are pretty durable.
But if you want to beef up that axle get a v6 3rd with a detroit or an arb and some Chromo shafts, and forget its back there.
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
jerusry
Oct 19, 2015 05:28 PM
toyoda8488
Jul 5, 2015 10:18 PM
