Sponsored by: CARiD
weber install use a gasket sealer?
Old Jan 10, 2012 | 08:54 AM
mitchen's Avatar
when installing my gaskets for the weber carb should just use the plane gaskets or should i use some kind of gasket maker/sealer? i know not to use RTV but wasnt sure if i would have intake leaks when using just the plane gaskets.
thanks,
Mitch
Old Jan 10, 2012 | 11:04 AM
Sensei's Avatar
Generally no sealer/adhesive/anything is used on carb gaskets, whether carb component related or base gasket.
The only reason you would have leaks is if the gasket was damaged on installation or your mounting surfaces are damaged.
kazuya2416
Apr 5, 2024 02:17 AM
dumpster84
Apr 30, 2016 06:03 AM
Sep 4, 2015 09:27 AM
Coreyr384
Jul 10, 2015 11:13 AM
Edionne13
Jul 9, 2015 01:59 PM
