Sponsored by: CARiD
87 runner cant pass DEQ
Old Feb 18, 2012 | 12:45 PM
Runner87Girl's Avatar
I have an 87 runner with a 20r, Weber carb. I just put a heavy duty Magnaglow cat on it today and drove about 50 miles and tried to go through DEQ and failed. I then tried driving another 50 miles and tried again. I have failed twice today. I need to know what i should do to get her to pass. I have about 9 days left
Old Feb 18, 2012 | 01:43 PM
James Woods's Avatar
Post up what the results of the 2 times you failed, they should have given you a certificate with where the readings are and where they should be at idle and at 2000 RPM's or something like that.
Old Feb 18, 2012 | 01:47 PM
topdog63's Avatar
Make sure its a cat that is legal for your state
Old Feb 18, 2012 | 01:58 PM
First time was HC 780/798 CO 3.7721/3.9003
Second test HC 646/686 CO 2.7756/2.8939
And the cat is legal in Oregon.
Old Feb 18, 2012 | 02:19 PM
rworegon's Avatar
What are the acceptable limits?
How many miles since it's had a tune-up? Plugs, plug wires, air filter, PCV valve, etc? Have you taken a look under the hood for bad or disconnected vacuum hoses?
While not exactly your year and engine, the basics still apply on page 2:
http://www.ncttora.com/fsm/1990-1995...e/idleando.pdf
Old Feb 18, 2012 | 02:38 PM
For the HC its supposed to be 220 and the CO is supposed to be no more than 1. It has about another 2500 miles before it needs a tune up. As for the oil change, its about due. It has a major oil leak that just started two days ago, appears to be the valve cover gasket. Or rather where the gasket should be. Since the guy that i bought it from used RTV and no gasket. And the carb air filter has been cleaned a few weeks ago. It has new cap and wires, replaced them about 6 months ago. All hoses are accounted for and hooked up. Keep in mind there is no smog pump or anything.
Old Feb 18, 2012 | 03:06 PM
bigt's Avatar
ummm well you might need the stock emission stuff..
normally best to pass the smog test before you change the carb and muffler..
do you have the stock things to put back on just to get it to pass?
Old Feb 18, 2012 | 03:34 PM
No i bought it like this. The truck is supposed have all the emission stuff and EFI and what not, but this isn't the motor that goes to this truck. So i think the specs would be different for a 22RE vs a 20R. I really don't know!
Old Feb 18, 2012 | 03:39 PM
bigt's Avatar
yea its a different engine.. is it possible to get it under a hotrod??
in my province "canada" if you put a bigger engine than what was available then you can get it plated hotrod with lax emissions rules... 1987 is also the cut off year for smog test here.. like my my 1982 never needed a test..
I wouldnt think they would run it when they look at it and see its a 22r and not a 20r they are ok with running a different engine than maybe you could find a friend with a similar truck and run it...
also make sure you run the truck really hot before you take it in..maybe someone else will chime in if those bottles of stuff at the parts store work
Old Feb 18, 2012 | 03:50 PM
Well correct me if im wrong, but i believe a 20R is smaller than a 22RE.
The cut off here is 75. I wish it was 85.
They run it with the VIN number so i can't have someone else go for me unfortunately.
I was told they frown upon motor swaps so i didn't mention to them it has a different motor than what its supposed to have.
It was well heated up when i took it through.
Old Feb 18, 2012 | 06:32 PM
So I think that you should try to retard the timing some, and maybe try some of the stuff at the parts store for passing smog tests, make sure that your EGR is working if you have one, also you might need to find the original smog pump stuff. I have never tried and don't know if it will actually work, but I have heard of people stuffing sponges into the exhaust to help pass.
Old Feb 21, 2012 | 07:32 PM
87-runner's Avatar
Make sure the o2 sensor is working or replace it.. If truck had carb originally it should be a feed back carb.. Lean it out as best you can and give it another try.
Old Feb 21, 2012 | 07:46 PM
What good would a working O2 sensor do a truck with a carb?
I had to reread it, Toyota never had an Aisin carb that was a feed back carb to the best of my knowledge, I think that was usually a Domestic thing.
Old Feb 21, 2012 | 10:07 PM
87-runner's Avatar
I said the same until I saw the difference between a before and after test on my friends 1st gen that had an aisin feed back carb..
Old Feb 22, 2012 | 08:12 AM
I dont know enough about carbs to know What you guys are talkin about. This is the first carb I've ever had...
Old Feb 22, 2012 | 08:14 AM
bob200587's Avatar
Take it to the mechanic and tell them to get it to pass.
Old Feb 26, 2012 | 04:33 PM
OkieRunner's Avatar
Best advice I know is find an 22RE with the injection and put it back original. Or just make it totally off-road.
MTLroadierunner
Jul 15, 2015 12:58 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
coryc85
Jul 7, 2015 04:05 AM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
