- Engine surges while driving
- swap to a 5sp?
- SAS Swap 95 4 Runner
- 62" springs from 00 chevy 1500 will they work??
- 94 4runner 4.3 swap. HELP!!!
- 2nd Gen diff in 1st gen??
- Best Winch
- gears
- Dohc 22R anyone?
- Stumped-new rebuild 22r runs rough
- Questions on dual transfer cases
- Replace CV Axle or Boot Only?
- got mud /water in my engine wat do i do ????
- 15 inch rims will fit a 2000 4RUNNER LIMITED?
- What clutch are you guys running with your 22r/22re
- 94 Runner 3.0 Engine Noise ?
- help changing fuel pump
- Axles that fit under a 88 4runner?
- Not getting fuel
- 22RE build
- Fixing diff leak, need help with parts list
- NEW PICS with Firestone Destination A/T 31's
- What can I do to lift the front for cheap
- Should I be concerned about my engine temp?
- steering wheel hub
- why does my new clutch chatter at me?
- 1990 Taillights compatible on 87' pickup?
- First time Carburetor rebuild help
- motor swap
- Oil pan question for 83 Toyota
- Detroit locker for DD?
- Fan clutch or no fan clutch?
- new taco owner
- oil viscosity question
- I have searched and searched.........
- Best suspension upgrades for a 98 4Runner SR-5?
- Changing front and rear brakes, how much fluid do I need
- newbie question about torsion bars
- Need helpage!
- 89 PU is there any way to make it a 4 runner?
- Newbie Chkin in
- 1/4" spacers required for 285 Nittos on an 02?
- check engine light
- new guy has another question....bout a spare tire carrier???
- Clicking from front end in 4WD High and Low
- want to run 31's --what gear do i need?
- 1st time clutch installation
- What to do when a bolt won't screw in?
- clutch?
- TRD Tundra coil lift...Which shocks to use?
- will 94 4 runner sus. lift fit 93 p/u?
- Front Rotor Upgrade Info Please.
- Clutch Start Cancel Button
- Newbie help
- 2003 tacoma driver side window won't roll down
- 92 frame compatable with what?
- oil change
- why did toyota go ifs?
- Good advice rocks
- O2 sensor question for my 1st gen pickup
- sometimes sounds like water or somthing
- engine noise
- Good websites for parts??
- tacoma interchangeable shocks
- 81-83 truck?
- Radiator Hot and Cold
- 2003 Transfer Case Oil leak
- Control Arm Replacing
- gearing
- 22re best hopups.
- Align cam and crank
- Repairing fuel/brake lines using flare tool
- Gears on Stock 89' runner?
- Headgasket Issues... :(
- 22RE head gasket HELP :(
- Got a tranny, 5mge, to sell
- Couple Newbie Q's....
- oil pressure
- 2003 4runner Headlight bulb
- 2nd gen low oil pressure
- Front IFS diff Breather
- help Doing a SAS with least lift?
- Rear window switch in cargo area
- clicking from rear
- Dumb suspension question
- 2001 4Runner Engine Surging/Stutter
- 3" BL and Towing
- engine swap need info? asap
- help with automatic
- 1986 4Runner fluctuates temp???
- Will these pathfinder wheels work?
- broken vacuum thing on intake manifold
- 93 4runner, cranks no start
- New 4Runner cleanup
- 5.29s rpms
- IFS Cleanup
- 87 pickup 22r carburated
- changing spark plugs on my 3rd gen?
- frame swap 88/85
- 89-94 2WD to 4WD Pickup/4Runner suspension compatability?
- need to tighten steering
- tach help
- basic help
- SaS preperation help needed.
- cab swap on 85 4runner frame
- Brakes w/ a Weird Noise question
- 1990 22re yota 4x4 pickup needs more POWAH!
- Need help with choosing a suspension lift kit
- Transmission diagnostic 95 4runner
- Tranny bolts to block
- i want to make a prerunner
- Which lift and how much?
- Light relay switch for 83 Toyota
- 96 4Runner rear coil & strut replacement
- 85 front axle question?
- 3.0vze won't start after jump
- Bumper compatability
- What to buy?
- any one have an 88 toyota pickup 2wd drive bed?
- Best Differential Ratio for Mudding?
- Aussie Locker... Which one????
- can this?
- Wanting to remove my cat emissions control ?
- Newbie 22RE questions
- Need your help asap
- lifting more questions!
- confused is it solenoid or complete rebuild
- starting problem and other...
- minkuni ?s
- Weber Carb help
- 1988 4runner v6 head gasket
- Rough Idle and Running Rich
- 22r doesnt wanna stay running when warm
- Gears?
- 4x4 will not engage
- 96 4 runner limited
- 3vze engine falters
- Counting Gears
- 85 springs(newbie)
- Whats the largest width I can go on a 96 tacoma?
- Newbie needs help
- 85 4runner
- anyone in raleigh nc?
- new
- Advice on LC install
- 86 4runner #4 fuel injector not firing
- I need help!!! No power 89 22re pickup
- Newbie Oil Change and weight?
- Front Bumper Topic.
- Help with getting a good seal on my shell.
- 85 22re efi
- 4Runner 95 Diesel 3L Motor Power Steering Issue
- Need new Shocks and possibly a Lift
- newbie transmission question plz help
- 1980 efi dash swap
- 22ret 2wd tranny
- 1989 4runner Nerf Bars---yes again
- Exhaut question
- Build Your Own Junkyard Double Case?
- 95 3.0 4runner Gremlins
- Locker questions from a noob
- 94 pick up suspension hardware info needed
- cheapest locker?
- locking diffrential
- lift question
- Under carriage Armor/Rear Lockers???
- 89 stalling loss of power engine light
- 95 3.0 4runner
- Transfer Case Bearings
- head gasket replacement
- Need help with Cargo light trigger
- newbie needs tech help?
- charging circuit fuse is blowing
- need a 5th wheel?
- Hood scoop insert
- couple Q's on installing new rear leafs & bushings
- Lift kits???
- 1989 4runner body lift removal
- Boulder--Carnage???
- Stock 89' Runner
- body and suspension lifts
- 2nd gen 4runner front end conversion
- fuel tank
- Clutch Problems 91 yotaaaa
- fly wheel torque specs
- 04 Tacoma TRD Locking Rear Differential
- SAS Kit Information
- Bump Stop ??s
- newbien
- Scraping noise when making left hand turns...
- Tube bumper legality question
- Went mudding and now my truck makes noise
- Skid Plate won't come off.
- Zuk mod/rear susp. question
- TRE question
- Stock suspension swap question
- Starter motor kaput; repair or replace?
- what is the best
- Brand Newbie Idle question (not asking about idle surge!)
- ome coils
- Dual case install question(s)
- What gas milage do you get with 5.29 gears?
- Soft TOPPER!!!
- Surging idol....
- Just starting out...1988 4x4 EFI
- I need help dont know whats happening
- How to deal with underbody rust?
- do i have a rear locker?
- Remove shaft for towing
- 97 ext taco how much would it cost for an SAS
- Another idiotic question from me.
- 4.56 Gears?
- what gears do I have?
- solid axle $45!!!
- Want to change 4 high to 1.1:1
- How Man liters of oil does the 3.0L V6 take?
- 95 4runner o/d button assembly
- I need help replacing my front end
- wanna make my 97 tacoma 2.7 bigger and better! Help!!
- 2001 4Runner Oil Change Help
- lift kits
- what axel to use
- Wheel Upgrade for 2wd 88 Pickup
- Emergency Brake Light Comes on Intermittently
- 79 2wd trans swap
- hey all
- 91 22re reving problems??
- 1989 22re wont start
- How to change my front wheel bearings
- Landcruiser FJ80 Driver Seat
- Transmission fluid change?
- Lubricating 4x4 stuff?!?!
- Transfer case/ differential questions.
- Adding rear ac to a 97 4runner....?
- gear rock/thump
- info 350 sbc 700r4 swap
- A bit of water in my headlight housing
- Performance questions
- CLutch Recommendations
- 22rte 4runner stalling in the middle of the freeway, need help
- some help deciding.
- Newb Head gasket question
- If you have ARB Front Air Locker on 3rd Gen, please read.
- What belt do I need?!?
- IAC valve question
- Front end vibration
- Too many choices!
- Newbie Off road
- Electrical lighting system
- need to find 3.5in lift rear u bolts asap!
