Zuk mod/rear susp. question
So I'm planning on doing the Zuk coil mod to fix my rear sag, but today when I was measuring I realized something I had not before. I have blocks in the back underneath the leaf packs, I'm guessing for the 4" pro-comp lift. Either way, my leafs are still sagged all the way to the overload springs. I measured 8" between the frame and top leaf, and 1.75" between the bumpstop and rubber snubber.
I emailed Zuk about this, but I wanted to get some opinions from YT as well. Should I remove the blocks and go with a 14" coil with spacers, or leave them in and go with a different coil/spacer setup? I imagine if I removed the blocks as it is, I would be totally up against my bumpstop.
I really just want it leveled. As for the stiffness, I was going to go with something like 100 or 150lbs/in. The only weight I carry regularly in the back in my full size spare. I would consider new leafs but zuk mod is more in the budget.
Maybe this will help. My distance from frame to leaf before was 8 3/4" I installed 14 inch, 125 lb rate springs and now that distance is 11 1/2 inches.
See if you can jack up the back end to 11 1/2 inches frame to leaf and then see how that would compare with or without the blocks in. If its got a huge rake, lower the jack 4 inches and see if its level.
Wouldnt the zuk mod just be a band-aid so to say? Seems like you need new spring reguardless of what you do. Why not save up and get what you need the first time around? I am not trying to be a jerk just understand how the mod would be better than new springs.
punks_is_4x4
08-21-2015 01:35 PM
icentropy
07-11-2015 07:21 AM
