Sponsored by: CARiD
Emergency Brake Light Comes on Intermittently
Old Oct 10, 2009 | 06:36 AM
4runnerman4's Avatar
Hello,
Have an issue with the Emergency brake light… it will turn on intermittently for a few seconds as I drive around town but the emergency brake is not engaged. I’ve noticed it turns on only when I make turns or speed up / slow down quickly but it’s not guaranteed to happen everytime… does anyone know what the cause is?
Thanks. Really appreciate you taking your time and sharing your expertise.
Old Oct 10, 2009 | 06:41 AM
crawlerjunkie's Avatar
Brake fluid level.
Old Oct 10, 2009 | 06:42 AM
Team420's Avatar
Maybe try checking your brake fluid level. If it is just above the min line, it will slosh when cornering, and set the light for a sec or 2.
Old Oct 10, 2009 | 07:17 AM
eddieleephd's Avatar
Usually is but if some how that does not fix it test the continuity of the switch open and closed and giggle it when testing. Most likely Fluid but hey some times.
And don't forget to post fix for future readers even if it is embarrassing!!!
I have had my share of Embarrassing fixes!!!
Old Oct 10, 2009 | 10:25 PM
One_96TR4's Avatar
If it's a 5spd the clutch fliud will also set it off.
Old Oct 11, 2009 | 05:58 AM
bootown's Avatar
When adding the fluid, make sure you go all the way to the max line. Mine was doing the same thing and was only about a 1/4 inch below max.
Old Oct 11, 2009 | 08:06 AM
James Dean's Avatar
If your fluid is low, you also need to check your brakes. The amount of fluid between the max and min is usually equal to the amount of fluid it takes to push the pads or shoes (from new to worn), if you don't have a leak.
Old Oct 14, 2009 | 07:14 PM
gotta say thanks to the people of the board. simple thing - refilling the brake fluid fixed it up. Thanks!
ashersullivan88yota
Jan 18, 2022 05:37 PM
fountain
Dec 31, 2015 06:08 AM
Sep 4, 2015 09:27 AM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
