Sponsored by: CARiD
2nd gen 4runner front end conversion
Old Oct 18, 2009 | 08:04 PM
Grunnen's Avatar
Has anyone actually done a late 2nd gen to early 2nd gen headlight/grille swap? I know I'll need the whole front grille, bezel, lights, bumper, valance. Will it all just bolt right up?
Old Oct 19, 2009 | 01:04 PM
Grunnen's Avatar
bump bump
Old Jun 30, 2013 | 03:11 PM
AzDirtRunner's Avatar
I also have been wondering the same thing? Has anyone done the swap yet?
Old Oct 4, 2013 | 05:24 PM
Bump!
Old Oct 4, 2013 | 07:22 PM
DeathCougar's Avatar
Why would you ever want to do something like that? Toyota upgraded the headlights for a reason. You need to change the Grille, Headlights, Side lights, Bumper, Valance, Turn signals, and most importantly the core support which means cutting/drilling/welding. You can't simply bolt it up, the core support is completely different. If you want the square headlights so bad (again, whyyyyy) just trade/sell yours and get a 90-91 4Runner.
Old Oct 4, 2013 | 07:45 PM
I've already done a bunch of mods to mine and I don't wanna build up another one right now.
My 95 runner has ZERO aftermarket applications for headlights i.e. projector, hid, halo, blacked out...etc.
The early years with the 4x6 lamps have a large variety of options.
The front support has 3 spot welds per side, and getting a front clip from a donor shouldn't be too expensive. The conversion should not be a major ordeal. I was just curious if anyone has already done it and if they had any tips/trucks that'll make the swap easier....
Old Oct 4, 2013 | 07:47 PM
It has more than 3 spot welds per side, I take it you have never done body work before?
Old Oct 4, 2013 | 07:53 PM
btw the reason there isn't much aftermarket support is because they already work pretty well. You can upgrade to HID's, though that tends to be $$$. However, for the money to downgrade to 90-91 setup then upgrade to better lights, you can get several HID kits.
Old Oct 4, 2013 | 07:58 PM
The fluted glass in the headlight just make the hids a glare. No, I've done minor body work before. Nothing major.
Old Feb 27, 2025 | 01:18 PM
osaucyone's Avatar
I don’t think you understand- these headlights may have worked fine 30 years ago but I’ll be ˟˟˟˟ed if they’re worth a ˟˟˟˟ anymore; the only aftermarket headlight options I’ve seen are either not road-legal or they’re over $500
Daneums
Jun 29, 2015 06:38 AM
marcusSRG
Jun 27, 2015 07:13 AM
YotaGreenhorn
Jun 27, 2015 07:00 AM
Niameyrider
Jun 25, 2015 05:50 AM
infinityisfive
Jun 16, 2015 06:51 PM
