Sponsored by: CARiD
oil pressure
Old Nov 5, 2009 | 01:33 PM
melkar37's Avatar
oil pressure
I have an 88 4runner that i just rebuilt and now i have no oil pressure and i replaced the oil pump. Any ideas?
Old Nov 5, 2009 | 01:41 PM
90-3vzeslug's Avatar
are you going by the factory gauge in the dash? these are prone to failure. get a mechanical gauge and test that way. mine read below "low" on the factory gauge and is in reality perfectly fine.
Also possible the oil pickup is clogged....
Old Nov 5, 2009 | 01:47 PM
melkar37's Avatar
thanks, i have both kinds of gauges on it and neither were registering any kind of pressure and when i was investigating i took the oil filter off and no oil had been circulated thru it??? and when i put the motor back together the pick up was totally cleaned in the parts washer that is why i feel real confussed
Old Nov 5, 2009 | 02:06 PM
did you prime the pump?
Old Nov 5, 2009 | 02:27 PM
Kiroshu's Avatar
Yea i was just about to ask that. Always primp the oil pump if its new. IS THERE OIL IN IT! Leaking oil? Where did you buy the pump and what kind.... Got the correct filter? You rebuilt the motor did you pump the strainer back in? It clogged? Oil goes from pan, pump, filter, and then bearings and gallerys..... so yea...
Old Nov 5, 2009 | 02:39 PM
melkar37's Avatar
well now i feel like a real moron i have never had to do that so how would you suggest i prime it?
Old Nov 5, 2009 | 02:43 PM
Matt90V6SR5's Avatar
Fail....hey slug is that a hood scoop?
Old Nov 5, 2009 | 02:53 PM
Kiroshu's Avatar
Pour oil into the pump and move it around alil to get it lubbed and ready for 1000000000's of miles.
Old Nov 6, 2009 | 12:50 PM
melkar37's Avatar
Should i do this through the relief valve on the housing or should i pull the pump off and lube it before i re install it?
Old Nov 6, 2009 | 12:52 PM
melkar37's Avatar
how would you prime the pump? the relief valve on the housing or take the pump off and lube it before reinstalling.
Old Nov 6, 2009 | 11:35 PM
Melkar how come your poimanently stuck on 5 posts?
Old Nov 7, 2009 | 04:29 AM
Haha that's no hood scoop, thats an extremely dirty bra on the front of the truck! I'd take it off the truck, but it's been on so long the damage is done. (thanks PO)
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
