Sponsored by: CARiD
4Runner 95 Diesel 3L Motor Power Steering Issue
Old Oct 23, 2009 | 04:18 PM
L0RDF3NRIS's Avatar
Hi Guys
Im a newbie here with little knowledge about cars and I looking for your advice.
I have a 1995 4Runner Diesel 3L Motor with a power steering issue, at the beginning I felt the power steering was working at half capacity because the steering wheel wasnt returning to its place by itself after turning.
Then I heard a humming / moaning noise while turning left and more recently a squealing noise when the steering wheel (that also have a play issue) turns until the end of its capacity
I was told to replace idler and pitman arms, which I did.
However problem continued, I suspected about the power steering pump, so I purchased one at ebay and a new belt from our local toyota dealer but after removing the original pump, we found I got it wrong and haven't been able to find the correct one.
So we decided to put all back together and now, the problem is worst, there is no power steering at all, and there is a moaning noise just turning a little the steering wheel instead of until the end like before.
Any advice ?
Old Oct 23, 2009 | 06:40 PM
tc's Avatar
tc
Sound slike your pump is bad.
Lemme guess - did you fill it with power steering fluid? (It takes ATF)
Old Oct 23, 2009 | 08:12 PM
L0RDF3NRIS's Avatar
Power Steering Fluid (generic)
Old Oct 23, 2009 | 08:19 PM
L0RDF3NRIS's Avatar
ok so I just need to drain the power steering fluid and fill it with ATF to fix it ?
or this could cause a severe permanent damage on my car ?
just to go and complain with the guy who did this
Old Oct 24, 2009 | 08:58 AM
tc's Avatar
tc
In my experience, using PSF instead of ATF spells quick death for the power steering pump.
Old Oct 24, 2009 | 09:34 AM
bigt's Avatar
my hiluxm has started in nuetral at first or when going slow the steering gets real tight..
i think its just my belt as the fluid is still full.. its not like the alt where there is a bolt to put tension on it.. i read in my manual i have to loosen both bolts then PRY the pump while someone else tightens those bolts..
Old Oct 24, 2009 | 10:53 AM
tc's Avatar
tc
Usually (not always), you can hear the belt slipping if that is the problem.
Old Oct 25, 2009 | 11:49 AM
bigt's Avatar
yeah it sounds likea belt slipping but the tires are really hard to move!!!
so ill have to find someone to tighten while i pry i guess.. ill go check out the situation.. thanks
Old Oct 25, 2009 | 01:24 PM
bigt's Avatar
ok so i was having a hella of a time finding the power steering pump..
BECAUSE IT WAS ON THE OTHER SIDE being right hand drive.. wow i feel so stupid well the belt is reallly really loose...
i dont have anyone to help me tonight would it be ok to drive 10km to work tommorow or will it sherd the belt?
1uzRunner
63
Nov 10, 2018 03:58 PM
choppe777
May 16, 2016 08:00 AM
firstgen88
Oct 7, 2015 04:53 PM
seab1209
Sep 3, 2015 05:41 PM
DiggnDeep
Sep 3, 2015 02:45 PM
