Sponsored by: CARiD
oil change
Old Nov 9, 2009 | 03:24 PM
nausetjeep's Avatar
oil change
I've changed the oil on my 03 4runner many times, and never had a problem. This time, the cap from the drain under the oil filter mount came off, and oil spilled on the belt and top of the ac compressor pulley. Now when I start and run it, there is a loud squeal that gets louder when I accelerate and nearly goes away when I slow it down. When the ac clutch kicks in, it squeals a bit more. Will this go away in time?
Old Nov 10, 2009 | 11:27 AM
GSGALLANT's Avatar
Maybe... but it will go away a lot quicker if you clean the pulleys and replace the belt.
Old Nov 11, 2009 | 01:14 PM
eddieleephd's Avatar
NO!! This will not go away until you use soapy water and wash the oil off then you can use a drop or two on the belt to make it sticky and no more squeak!!
they do make belt dressing compounds but the old school is to soap.
When dish soap gets spread out and drys up it becomes sticky and stops squeeling belts
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
horunner1x
Jul 10, 2015 06:33 AM
