PDA
View Full Version : Newbie Tech Section
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52 53 54 55
  1. rust
  2. What makes a 87 4runner a sr5?
  3. Newbie Question
  4. Reverse Problem with FZJ80
  5. AIR INTAKE MOD, will this work??
  6. NEED to replace 3rd gen front bumper / taco conversion??
  7. Recall issues
  8. Rear axle leak?
  9. 22re replacment motor
  10. New guy/wiring help 81 pickup
  11. The New Rig
  12. Just pick up a 2dr 1990 runner
  13. transmission
  14. brake booster?
  15. Driveshaft question
  16. adjustable panhard bar
  17. Steel Wheels
  18. 22re fan clutch
  19. MySpace
  20. How bad is it to have a leaking main seal?
  21. Transmission Problem
  22. scooped hood for 04 taco?
  23. cai for 04 3.4l V6 taco
  24. 84 4runner wheels don't fit
  25. Vacuum diagram
  26. no start after head job
  27. Wont start
  28. 1991 4runner 22re Fuel Rail Removal
  29. 1984 4runner
  30. Lift ideas
  31. RUF setup question
  32. How many amps do I really need to weld auto body sheet metal?
  33. Remanufactured CV axle, halfshaft
  34. Tranny removal help
  35. herculiner help
  36. 4Runner 1st gen and 2nd gen aftermarket bumpers
  37. 91 Pickup Auto diff and Trans. ?s
  38. 92 4runner 3.0 roll over won't run
  39. Canada (Canadian), 3vz-e, power steering leak
  40. Blown Head Gasket ?
  41. 2001 Sequoia - Your thoughts?
  42. Engine Swap
  43. Need Help
  44. Is the 21-ru the same as the 22r
  45. Ecm bad or not?
  46. cold start issues on 88' 4runner
  47. 94 toyota pickup tires
  48. Axle breather question
  49. Revtek with OME leafs
  50. HELP fast
  51. 35 inch tires?
  52. E-brake cable question
  53. Idle issues 92 4runner
  54. 1986 Toyota 22ret ?
  55. Steering, bad noise when turned fully right,linkage groaning
  56. 1993 Toyota 4x4 P/U V6 ?'s
  57. question on steering
  58. 88' Toyota Pickup
  59. 4Runner - 2nd Gen and 3rd Gen body parts compatibility
  60. What Should I Be Looking For .....
  61. torque for the crank bolts
  62. 1994 4runner 2wd to 4wd
  63. Beds ?
  64. body work help!!!
  65. keep or sell advice please
  66. '88 4Runner transmission identity
  67. ECU Injectors & Knock Sensor
  68. Lift Plan?
  69. Loss of power
  70. AMSOIL Brands
  71. 87 4runner lift and tire questions
  72. Where exactly is my speed sensor?
  73. 91 p/u Coil lift...??
  74. 3/4 ton axle swap front and rear on 91 toyota
  75. Intake Box?
  76. I want to do a 2x4 to 4x4 conversion
  77. Custom skid plates?
  78. 22RE transmission question
  79. TRD Supercharger for 3.4L - which one?
  80. 93 toy wondering if they are good for bush
  81. 3rd Gen Black Bumpers?
  82. Lift idea ?s
  83. Rear window problems.
  84. HAI Diaphragm
  85. Which size do I get? (Rims)
  86. maximum tire size for my truck
  87. Wanna Lift My 92 Surf
  88. rebuild
  89. Need advice for replace valves since head off
  90. '88 4Runner center link?
  91. rear brake line to,,,have no idea what this is
  92. trouble codes?
  93. help me ID this part
  94. Shackles
  95. 86 22re no power
  96. High-Flow Air Filter Q's
  97. best tire for me
  98. 91 2wd 5speed engine into 86 4runner auto
  99. Just ordered a lift kit !!!!!
  100. Draining voltage!
  101. factory tacoma e-locker
  102. 1991 V6 water outlet bolts.....help!
  103. speed bleeders info wanted
  104. Funky Idle at a stop, while applying the brake.
  105. New Arb Bumper
  106. Turbo
  107. lift on my 4runner
  108. 87' 4runner speedometer recal
  109. sr5 or not
  110. ok im confused about all this gear stuff.
  111. Replaced the fuel filter today :)
  112. Yota Tech has a chat room?
  113. XREAS bleeding?
  114. california headers
  115. gears?????
  116. Suggestion on a 91 pick up
  117. 4 Wheel drive won't disengage
  118. Considering FJ, how hard to wheel?
  119. What happens if you over tighten the plugs?
  120. I need a new head! Help!
  121. maximum tire size, '01 SR5
  122. 22re Starter, same between generations?
  123. white smoke
  124. Squeeling noise at idle.
  125. What year(s) should I look for to find a front axle for a SAS?
  126. Temperature gauge not working .
  127. Yota Techs..need your help
  128. pics of 235/75/15 bf goodrich mud terrain t/a km
  129. I need info. on a sensor that's located in the fuse block .
  130. Really bad fuel mileage
  131. Cranking issue: maf? fuel pump?
  132. any ideas on new color?
  133. Charging problems
  134. what mods to make 02 Tacoma "quicker"?
  135. 87 22r carb re-build ?
  136. how much is reasonable to run off my battery/alternator
  137. compatability
  138. 86 4 runner trany
  139. Help! Quick!
  140. lift and tires
  141. new cd deck installed, but what about the gap?
  142. Really wobbly stearing... Shackels?
  143. 88 V6 3vze man. to 89 V6 3vze auto?
  144. 1st Gen Lift for new tires
  145. Which is the better motor for a 87-89 4runner?
  146. How much do Bj spacers cost and!!!
  147. door buZZZZer!!!!
  148. 22rte swap into an 85' re
  149. 3.0 trans help
  150. 3.4L PCV Valve is a mother
  151. Rebuilding engine, what the heck are these???
  152. Fuel Tank Relocation
  153. Transmission Leak!
  154. lifting 2wd
  155. Off road upgrade
  156. Motor knockin
  157. What tire will fit on my truck?
  158. Will the TRD suspension for my T100?
  159. speedometer went out!
  160. Experienced Painters?
  161. Cant find 22re Wiring Harness
  162. 3rd gen pickup tube bed?
  163. Front bumper and other LED help
  164. stock gears.
  165. Locker question
  166. 81 toyota pickup 22r 4x4 4 speed
  167. lighting
  168. gears
  169. 22re wont start
  170. Clutch Replace
  171. 2nd Gen 4runner Help Needed
  172. ITBs on a 22R?
  173. missing jet to choke opener
  174. Suspension questions for 2002 4runner sport
  175. 1998 4-runner 4x4 squealing noise
  176. Head Gasket Recall
  177. Transmission swap?
  178. Going to bigger tires!! Confused on diff sizes...
  179. Hvac Panel
  180. Help on toyota pick.. PLZ!
  181. method for determining true mileage?
  182. how to rebuild a chain drive t-case 95 4runner v-6 auto
  183. What mods make sense for deep snow?
  184. Hood paint faded. Would a scoop help?
  185. Hydrolysis!
  186. New 4 runner owner
  187. 92 22RE engine Problems ROUGH IDLE
  188. Newbie rebuilding a 3VZE. Should I attempt it?
  189. should 3.0 have this little power
  190. 97 runner, question about shocks
  191. Master cylinder change out...
  192. Pickup
  193. Trans and t-case help
  194. Stock 22r cam lobe center
  195. my very sick 22-r eats fuel like i own a gas station
  196. Not completely Toyota related, but..car won't start
  197. 87 4-runner toytota with a problem i dare some one to help me solve this BIG isuie
  198. Confused on cylinder #/misfire codes
  199. 22re head with 22r block and manifolds
  200. wheels??
  201. 84 4runner fuel fuse?!
  202. What is this?
  203. need a little help
  204. Thermostatic Valve
  205. 92 runner bad 3.0 can i put in a 22re?
  206. New guy....
  207. serious flooding
  208. largest size tires for 1999 4runner sr5 2wd
  209. I've got a question
  210. My New/Used 95 4 Runner Broke Today
  211. Lifting A 97' 4 Runner
  212. Help Timing 22Re engine
  213. slipping t-case???
  214. tranny swap?
  215. Removing Posts
  216. 97 runner tundra upgrade. re purchase questions
  217. Popping coming from the front end
  218. Fuel gauge stopped
  219. Warn Winch XD9000
  220. Dang Hydrocarbons
  221. anyone know anything about thermogasket
  222. Bad Deal
  223. need help
  224. 1st gen. 4runner grill removal
  225. few questions about a possible good deal on a runner
  226. Cylinder Head Cover gasket replacement
  227. I keep blowing the 7.5 A IGN. fuse
  228. Help getting wheels off..
  229. Engine Wont Idle
  230. 83 bed vs. 84 bed
  231. question about torsion bars
  232. changing shocks...in my garage
  233. 1988 1 ton will not start when hot
  234. Brakes or not brakes?
  235. 1990 3vze fuel line on the left side of intake
  236. cylinder 2 not firing!!!
  237. new to forum
  238. Buying a 3rd gen T4R - Got a few questions
  239. fj coils?
  240. diff breather ends
  241. Total newb with questions
  242. What exactly am i spoused to grind off?
  243. Quick Question...
  244. 98 Tacoma - LSD or locker?
  245. 92 3vze P/u
  246. Fuel and timming maps
  247. oil pan
  248. Glove Box lock - where to buy for 2004 4Runner
  249. Motor Question?
  250. Help! Torsion Bars?
