Sponsored by: CARiD
Trans and t-case help
Old Sep 11, 2008 | 06:30 PM
DWEINBERG01's Avatar
Will a 5 speed trans from a 92 toyot p/u with the 3.0 mate up to a 95 3.0 motor that originally came with an auto? If not what is needed to make it work.
What is needed to mate the gear driven t-case to that transmission?
What is an average asking price for that transmission and also for that t-case? I found some in a junkyard, the front of both trucks are toast, but from the fire wall back, there is no visble damage.
Also can I get a quick description of the differences between top-shift t-case and forward shift t-case.
Trying to see if it would be worth my money to pull them and put them in my runner. Any help is appreciated.
Old Sep 11, 2008 | 08:21 PM
Jay351's Avatar
Yes, the r150 out of the 3vze 5sp will bolt right up to your automatic 3vze. But it requires some work to get it to run.
Things you need:
r150 + transfercase (about 300 bucks used) (with shifters!)
Clutch kit, flywheel and flywheel bolts
Clutch/brake pedal bracket
All related clutch plumbing and parts
rear driveshaft out of the manual truck
Tranny x-member from manual truck
And you need to jump two connectors to get it to run with the 5sp.
Old Sep 12, 2008 | 06:07 AM
4Crawler's Avatar
Top vs. forward shift:
http://www.4x4wire.com/toyota/tech/topshifter/
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
beebeeri000
Oct 2, 2015 10:42 PM
tshort48
Sep 27, 2015 01:04 PM
Odin
Sep 26, 2015 06:56 PM
