Sponsored by: CARiD
lifting 2wd
Old Sep 24, 2008 | 03:49 PM
hmmwv15's Avatar
lifting 2wd
My pickup is shorter than most passenger cars out today. While lifting it would cut down on gas mileage a bit, I'm to the point where the bumpers sit so low I would either run underneath the average civic, or one would park right in the back of my truck in a rear end collision. I was just curious about how I would lift the front end around 4". I figure I could get an IFS rear axle housing and diff from a 4x4 (converting it to spring over) and swap the axle shafts and brake assemblies into the new housing. But I only have about 1 1/2" of lift if I crank the torsion bars all the way. I don't know of anyone who makes IFS drop brackets for the 2wd, or if I could modify a 4x4 one to fit. If I ever did this to my DD I would definitely do it on the cheaper side, so since I can't figure out how to lift the front more than 2 inches, I would be stuck with aal's in the rear, and that's just not enough. If I lift this thing, I want to go big! So basically, does anyone have any more info on a 4" lift for the front? I can take pictures or if you have a haynes manual there are some good black and white ones in there.
Old Sep 24, 2008 | 03:56 PM
4Crawler's Avatar
2WD ball joint spacers are one option up front:
http://www.4crawler.com/4x4/ForSale/...ntSpacer.shtml
Or you could go with one of the long travel 2WD prerunner type kits.
Old Sep 24, 2008 | 04:05 PM
jason191918's Avatar
here is what not to do...
https://www.yotatech.com/forums/f31/...safety-151479/
Old Sep 24, 2008 | 04:12 PM
hmmwv15's Avatar
I'm such an idiot! I totally forgot about ball joint spacers! That would still leave me with 3" in front if I did both though.
Old Sep 24, 2008 | 04:14 PM
hmmwv15's Avatar
Originally Posted by jason191918
AHHH!
Old Sep 24, 2008 | 07:45 PM
TACO626's Avatar
I've heard horrible stories about that bj spacer
Old Sep 25, 2008 | 01:54 PM
hmmwv15's Avatar
Go on...
Old Sep 25, 2008 | 06:16 PM
Trustyrusty's Avatar
Pics or it didn't happen.
Old Sep 29, 2008 | 05:19 PM
hmmwv15's Avatar
I haven't heard any horror stories about the spacers, so as of now I have settled on swapping a 4x4 rear axle and then cranking t-bars with the bj spacers in the front. I will have to get it aligned after the T-bar crank. While it may be raked in front a little, I don't think it will matter too much, especially when the rear leaves start to sag! If I do any other mods after the lift, it would probably be an auto locker for the added traction offroad, after all I'll still be running the stock size street tires so I'll need all the extra traction I can get! Even though it won't see much off road use. Who wouldn't like to do the same to their DD?
Old Sep 29, 2008 | 05:33 PM
SpecialScottie's Avatar
Sounds like a good plan.
I DD my 2wd and it also sees dirt once in a while
Sep 4, 2015 09:27 AM
Ernie217
Aug 14, 2015 05:25 AM
Pedalpwr27
Aug 13, 2015 06:37 AM
coffey50
Jul 28, 2015 10:55 AM
colasurdo
Jul 16, 2015 11:32 AM
