87 4-runner toytota with a problem i dare some one to help me solve this BIG isuie
From: i live in ontario ca lived here for bout 8 years
it all started when i had a cracked exhoust manifold a major exhost leak so i put a after market maifold on my 22 r it had 150,000 miles on it and after starting it the manifold turned bright white hot like the sun Whoa .... so i put the old manifold back on cracks and all and then the old manifold turned bright red hot this never happened before so now i blow a engine and put a rebuilt 22 r long block and the same thing happens the exhost mnanifold still glows red not just red but BRIGHT RED i have no power i get 9 maybe 10 miles to a gallon i can go 4-wheeling (which i love more than anything) this is my only mode of transportion it runs rich you can tell by looking at the tail pipe ive had this problem for 3 years or better and cant for the life of figure out and nobody else can after 3 dionostic check up at $170 bucks a piece almost $600 later nothing can any 1 in this world please HELP me with this problem god bless if u can if you care to talk to me you can call me on my cell number is 909- 509-0793 call me anytime if im busy i most certinly will call you back just tell me it for my truck plz thank you & may god bless
The test pipe is just to make sure if it is or isn't the cat!
Imo, that might be the best bet before throwing a bunch more money to find out the problem!
(Btw hows the timing? when we first got my v6 running, it was running out of wack and made the exhaust manifold glow red! Corrected the timing and problem solved!)
Good luck
Good luck
Yotadawgjr
10
Aug 23, 2015 10:51 AM
cgilley
Jul 15, 2015 03:32 AM
