Sponsored by: CARiD
87 4-runner toytota with a problem i dare some one to help me solve this BIG isuie
Old Sep 10, 2008 | 08:34 PM
larmo's Avatar
From: i live in ontario ca lived here for bout 8 years
it all started when i had a cracked exhoust manifold a major exhost leak so i put a after market maifold on my 22 r it had 150,000 miles on it and after starting it the manifold turned bright white hot like the sun Whoa .... so i put the old manifold back on cracks and all and then the old manifold turned bright red hot this never happened before so now i blow a engine and put a rebuilt 22 r long block and the same thing happens the exhost mnanifold still glows red not just red but BRIGHT RED i have no power i get 9 maybe 10 miles to a gallon i can go 4-wheeling (which i love more than anything) this is my only mode of transportion it runs rich you can tell by looking at the tail pipe ive had this problem for 3 years or better and cant for the life of figure out and nobody else can after 3 dionostic check up at $170 bucks a piece almost $600 later nothing can any 1 in this world please HELP me with this problem god bless if u can if you care to talk to me you can call me on my cell number is 909- 509-0793 call me anytime if im busy i most certinly will call you back just tell me it for my truck plz thank you & may god bless
Old Sep 10, 2008 | 08:38 PM
tc's Avatar
tc
Sounds like a plugged cat to me.
Old Sep 10, 2008 | 08:40 PM
ScottyC's Avatar
Ditto, cut the cat out, lay a temp pipe in place and see what happens.
Old Sep 14, 2008 | 09:18 PM
khoopes's Avatar
Is the Cat a common problem? I wonder if I should just remove mine for good measure in my 88 22RE?
Old Sep 15, 2008 | 05:12 AM
tc's Avatar
tc
1. No it's not a common problem.
2. It's a Federal offense to remove emissions equipment. If you have to get smog tested, it will fail for sure without it.
Old Sep 15, 2008 | 07:41 AM
netwt12's Avatar
you need a new catalytic converter.
Old Sep 15, 2008 | 08:19 AM
904_runner's Avatar
The test pipe is just to make sure if it is or isn't the cat!
Imo, that might be the best bet before throwing a bunch more money to find out the problem!
(Btw hows the timing? when we first got my v6 running, it was running out of wack and made the exhaust manifold glow red! Corrected the timing and problem solved!)
Good luck
Old Sep 15, 2008 | 08:56 AM
96redtoy's Avatar
You said it was a 22r meaning that you also have a carb your mixture might be way leaned out causing the red hot pipes.
Old Sep 21, 2008 | 02:07 PM
89huntinrig's Avatar
I agree.. Air/ Fuel mixture is way off... I had that happen to mine... Wrong computer caused it to run way to rich and the manifold to get cherry red...
Old Sep 21, 2008 | 03:33 PM
iselloil's Avatar
Check for a crack in the base of the carb,or base gasket.Somewhere in the intake area its gettin extra air.Improper fuel mix.
young buck
18
Aug 27, 2018 02:40 PM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
daddio
Jul 18, 2015 10:20 AM
cgilley
Jul 15, 2015 03:32 AM
wilbertd
Jul 6, 2015 07:39 AM
