Sponsored by: CARiD
Engine Wont Idle
Old Sep 2, 2008 | 11:44 AM
FRED5's Avatar
Engine Wont Idle
NEW TO SITE. I HAVE A 93 toyota 3.0 dually. just finished putting together new short block and heads. i have checked everything on this truck, and cant find why it will not idle smooth its rough and even turns off at times.if i remove the oil cap from valve cover it turns off. if i remove the breather hose from the air intake tube it turns off.placed new pcv and same problem. like to know if this could be caused by egr or as reed valve. like some suggestions. thank you.
Old Sep 8, 2008 | 12:03 PM
joesscamaro's Avatar
I know very little about Toyotas...new to the site and Toyotas...but I'll throw some ideas out there. I need to learn too.
1) Vacuum leak? Spray some carb cleaner on vacuum lines, and if you have a leak...you'll know it.
2) IAV?
Old Sep 8, 2008 | 03:20 PM
FRED5's Avatar
i have tried that and many other things. i think i am going to find a place that can check it out for cause i am stuck....
Old Sep 10, 2008 | 09:06 PM
Ron Helmuth's Avatar
okay if all the vacuum lines are good -I am with joesscamaro on this one-the symptoms are exactly that of a vacuum problem...
then I am thinking that something is plugged or routed to itself that the vacuum lines connect to. I have to think that in the rebuild you took something apart that is now not put back exactly right.
You of course have double and triple checked all of it but you are tired of it and it is much like catching your own spelling errors-better to have a 2nd set of eyes look it over. Of course, free eyes always the best kind.
gots to be some other Miami guys out there that could look it over and spot what you have missed....
Not throwing any error codes obviously.... computer is trying to do its' thing -oxy sensors plugged in and all of that....
just talking... think it out....
let us know please this is how we all learn.
Old Sep 21, 2008 | 04:50 AM
FRED5's Avatar
Had Second Set Of Eyes Look Over Truck. We Measured The Ecm, Tps All Vsv Checked Everything.what We Found Is That When Engine Gets Hot The As Reed Valve Stops Working. I Am Trying To Find Someone In The Area With A Good Computer To Check It Out Since I Dont Get The Engine Light On. Anyone Out There From Miami?
smthwsn357
May 1, 2024 07:28 AM
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Jnkml
Jul 6, 2015 01:20 PM
