Sponsored by: CARiD
35 inch tires?
Old Oct 22, 2008 | 09:33 PM
94toy4x4fever's Avatar
35 inch tires?
I was wondering if 35's will fit on my 4runner! It has a lift on it already that the PO put on. Im not to sure how much it is. I measured the fromt sway bar brakets and the are about 3 inches long. so I was wondering if 35's would clear. I dont mind if they rub a little bit but not alot. If any one could shed some light on this that would be great. Thanks
Old Oct 22, 2008 | 09:36 PM
Tofer's Avatar
Sponsor
no....
Old Oct 22, 2008 | 09:49 PM
88wildrunner's Avatar
the best way to see is to flex your suspension out like on an rti ramp or something, then take a tape measure and see how much extra clearence you have. if you have 31's like your sig says then make sure you have at least 5 or so extra inches of clearence around the fenders, leaf springs, sway bar, arm ect.
but since you dont know if what your lift is i doubt they will fit, since it takes a lot of lift to properly clear 35's on a toyota.
Old Oct 22, 2008 | 09:54 PM
olharleyman's Avatar
You need at least 4" of lift to clear them but if you have a bracket lift you will also need to do some pinch weld trimming and a wheel with 3.75 -4" backspacing to run a 12.5 wide tire.
If you have a 5 speed you are gonna want or need a set of 5.29 or 5.71 rear end gears front and rear to get any kind of decent power out of the set up. I believe and not quite sure but I believe with auto tranny you will need 4.88 rear end gear sets both ends.
Flying91
45
Apr 11, 2024 04:39 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
coffey50
Jul 28, 2015 10:55 AM
Yotoder865
Jul 9, 2015 07:51 PM
