Sponsored by: CARiD
Thermostatic Valve
Old Sep 9, 2008 | 07:04 AM
83's Avatar
83
Thermostatic Valve
What's it do? I put the intake back on my engine, and one of the two bolts on this valve got a little stripped. It's tight, but I hit a point where it just started to spin and not get tighter. Obviously it should be snug, but I'm just making sure it's not something carrying fluid, or is completely essential to having the truck run right. I'm just trying to get away with not buying helicoil or some kind of tap just yet.. It's on my 22R
Old Sep 9, 2008 | 08:50 AM
tc's Avatar
tc
Do you mean the thermostat?
If so ... coolant runs through there ... under pressure. If it's not tight, you're gonna have a major coolant leak.
Old Sep 9, 2008 | 10:59 AM
83's Avatar
83
No....there's something that attaches to the intake side of the head, that you can get to once the intake manifold is off. It's got a couple vacuum looking hoses coming off the top, and a long hose that goes down off the bottom. It attaches to the head, using part of the intake manifold gasket. I've got an '85 FSM I'm working off, and it calls it the thermostatic valve..I think. It's got two drawings on that page, says to take the egr off off, then the intake manifold, then the thermostatic valve. I'm just guessing the first drawing is the egr, and second is what they're calling the thermostatic valve.
Old Sep 9, 2008 | 11:17 AM
83's Avatar
83
How about BVSV? I'm seeing a diagram calling it that...
_Nicco_
Sep 21, 2015 03:06 PM
LotOMiles
Sep 14, 2015 11:45 PM
noahstancik
Sep 10, 2015 10:47 AM
idadan208
Sep 7, 2015 09:06 AM
--Oz--
Sep 6, 2015 01:06 AM
