Sponsored by: CARiD
Quick Question...
Old Aug 27, 2008 | 05:30 PM
The Stig's Avatar
Quick Question...
i'm a noob at engines so i have a question to ask.
i'm inspecting my TPS sensor to make sure that the resistance is on the right spot. but in the toyota factory service manual, it says that i need to use a vacuum on the throttle, just what is that vacuum? thanks!
Old Aug 27, 2008 | 05:54 PM
Elvota's Avatar
Originally Posted by The Stig
... it says that i need to use a vacuum on the throttle, just what is that vacuum? thanks!
Vacuum is created by the intake... but I am not really sure as to your question.
This is a great article on the TPS and adjustment:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Aug 27, 2008 | 06:00 PM
The Stig's Avatar
thanks, this will be very helpful, well on the FSM manual, the first step in inspecting the TPS sensor is "apply a vacuum to the throttle." if that helps.
Old Aug 27, 2008 | 06:07 PM
Bigblock's Avatar
Probly the dashpot that slows the closing of the throttle.If you're checking the TPS then you need it at the fully closed position.
Bigblock
Old Aug 27, 2008 | 06:09 PM
The Stig's Avatar
Bigblock
alright thanks, am i able to adjust the TPS while it is removed from the engine?
Old Aug 27, 2008 | 06:19 PM
bigt's Avatar
THE STIG is your name from top gear if so you rule
Old Aug 27, 2008 | 06:23 PM
The Stig's Avatar
LOL, i freakin love that show!!!!
Old Aug 27, 2008 | 06:27 PM
4Crawler's Avatar
Yes, but it needs to be attached to the throttle body to do so.
Old Aug 27, 2008 | 06:36 PM
The Stig's Avatar
so that means that i am able to work with the Throttle body while it is removed from the engine.
Old Aug 27, 2008 | 06:42 PM
4Crawler's Avatar
Yes, as pictured on the web page posted earlier:
Old Aug 27, 2008 | 07:00 PM
The Stig's Avatar
alright, thanks, this will make life much easier for me.
Old Aug 28, 2008 | 01:29 PM
Jay351's Avatar
Yeah, the 3vze has like NO room to get at the TPS bolts when the throttle body is installed.
Pull it off and bench test it. You can also clean out all the gunk build up.
Old Aug 28, 2008 | 06:09 PM
The Stig's Avatar
agreed, it's practically located at the worst spot possible. well hope to get some work done this weekend. thanks.
Old Aug 30, 2008 | 01:58 PM
The Stig's Avatar
I've just got finished with adjusting the TPS Sensor, and now it runs great, this is a little off topic but, anybody know how to increase fuel mileage?
Old Aug 30, 2008 | 02:00 PM
bigt's Avatar
i bought a diesel lol
Old Aug 31, 2008 | 04:49 AM
FredTJ's Avatar
<SNIP>
Yup, put a 2x4 under the gas pedal.....
Fred
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
zytra
Jan 24, 2019 03:16 PM
charlie_fong
Sep 27, 2015 10:06 PM
