Sponsored by: CARiD
1990 3vze fuel line on the left side of intake
Old Aug 30, 2008 | 02:59 PM
BMJ's Avatar
BMJ
My sons toyota has sprung a gasoline leak at this junction on the intake manifold on the left side, also has some sensor that plugs into the junction. Can anyone tell me what this is? Part to order? Line says toyota fuel and is of small diameter surrounded by a rubber sheath. Any information would be greatly appreciated since this is how he and his sis get to school.
BJ
Old Sep 6, 2008 | 12:40 PM
BMJ's Avatar
BMJ
NEW Problem 3.0 WHATS NEW HERE?
Got the sons top end/ intake plenum and vacuum hoses back according to the nice online FSM. I saw that there was some carbon outside the gasket area on # 4 round inlet counting from the front. So placed a nice thin coat of permatex on the gasket. Torqued it down intake plenum. New cold start injector line is in and no leaks, but NOW there is this Fuel line that the previous owner had capped off. If you are at the passenger front tire looking at the intake. It is just below the farthest left top vaccum line slightly diagnally left. This was capped off? now the hose with the screw to cap it off on that line that went on there spews gasoline like crazy. Vehicle runs fantastic now, maybe all along needed lines put back where they belong, better than when at the mech. WHERE DOES THIS FUEL LINE GO or where should it go.???? fuel pressure seems high coming out of it. Why did the former owner cap it off? It is under such high pressure, not even a new hose with a bolt to seal it will cap it off!! It never leaked before with just the hose and bolt in the other end to cap it off so once again, I'd appreciate any feed back from YotaTechies. I ask for my eyes are burning red from gas spewed in them unfortunately so I'm not doing any intensive reading.
After goofing and looking now it seems that this metal line is the one that runs to runs to a vaccum valve just in front where the throttle cable connect on the right driver fuel rail???
Thanks again
Bryan
Old Sep 6, 2008 | 12:44 PM
BMJ's Avatar
BMJ
new fuel line/bolt will not cap off. can't type today
Jmiller1023
23
Aug 6, 2015 07:03 PM
dirtrider0129
10
Jun 24, 2015 12:24 PM
EClayton08
Jul 30, 2002 10:34 AM
