Sponsored by: CARiD
22re Starter, same between generations?
Old Oct 1, 2008 | 11:09 PM
Jay351's Avatar
I need to do the starter contacts on my girlfriends 95 4runner with a 22re. I found a used starter with almost new contacts for 30 bucks, considering the contacts are about that from the dealer, I wanted to just swap it out.
Only thing, the starter is from a 87 22re. So, are they interchangeable? Or should I just rebuild the sucker... Thanks guys!
Old Oct 2, 2008 | 06:46 AM
22mr2's Avatar
The solenoids themselves all wire up the same, but the body where the starter motor itself mounts is a little different. Id say if you took the back case off the solenoid off(the three bolts) the internals of the solenoid should be the same but your not really going to know unless you tear it apart
Old Oct 2, 2008 | 06:53 AM
4Crawler's Avatar
I know there are some internal changes in the contacts from year to year and there are two different power rated starter motors (1.0 and 1.4 kW) but I think they are all interchangeable on the engine, but I am not 100% sure on that.
Replacements contacts are also available for less than the dealer charges if you wanted to go the rebuild route:
- http://www.4crawler.com/4x4/CheapTri...OnlineOrdering
Old Oct 2, 2008 | 07:43 AM
jason191918's Avatar
You could do a part number comparison at:
www.napaonline.com
http://www.trademotion.com/partlocat...?siteid=214074
http://www.toyodiy.com/
Old Oct 2, 2008 | 10:14 AM
Jay351's Avatar
Ahh, I think im just gonna rebuild the sucker. Chances are im gonna need to do it on my truck soon. Might aswell learn how to do it.
Thanks for the helps guys.
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
clok
Aug 1, 2015 09:42 PM
ZONAYODA
Jul 13, 2015 07:17 PM
colinmil
Jul 6, 2015 04:03 PM
