Sponsored by: CARiD
Lift idea ?s
Old Oct 12, 2008 | 07:08 PM
t_boneshacone's Avatar
Lift idea ?s
ok, so i have blocked and shackled the rear of my truck but the front is still low, so i was wondering instead of buying new leafs for my truck, could i buy some cheap junkyard leafs off a full size or just a bigger truck and put them on my little toyota, would it give me a little bit of lift seeing as its on a smaller frame, and how hard would they be to bolt up
Old Oct 12, 2008 | 07:10 PM
jason191918's Avatar
What truck?
Old Oct 12, 2008 | 07:12 PM
my truck is an 85, the truck i would get them off of is just some big old truck
Old Oct 12, 2008 | 07:15 PM
scuba's Avatar
63" chevys
Old Oct 12, 2008 | 07:17 PM
thats how big of ones i need to get off a chevy
Old Oct 12, 2008 | 07:18 PM
Hayes's Avatar
honestly, just wait and buy springs. Springs for a heavier truck are going to ride rougher... Springs are not that expensive, when it comes down to it.
Also, while you are at it, ditch the blocks.
Old Oct 12, 2008 | 07:20 PM
Hayes's Avatar
Originally Posted by scuba
63" chevys
those are for the rear, he is asking about the fronts.
If you get 63" chevies for the rear, you can move your rear springs up front and get approx 3" of lift. You would have to cut and re-weld the spring hangers.
Old Oct 12, 2008 | 07:21 PM
i didnt put the blocks on there they were on there when i got it, thats why i was gonna look for some springs for maybe the whole thing, front 3" or 4" lift springs are 200 the cheapest i have found
I have no idea what I am talking about, but what if one did 63" Chevy's up front?
scuba's Avatar
I knew i messed up as soon as I posted that, im not a SFA guy
Old Oct 12, 2008 | 07:22 PM
and the springs are pretty saggy on the back too, and to move the hangers i dont think would be too hard
Old Oct 12, 2008 | 07:26 PM
Hayes's Avatar
I honestly couldn't tell you what would happen. I would think that they are too long to try on the fronts...
It's alright... You get one muligan and then we start the floggings!
Old Oct 12, 2008 | 07:29 PM
tc's Avatar
tc
Taking the blocks out will level it out. Save up and get some GOOD springs.
What size tire are you trying to run?
Old Oct 12, 2008 | 07:38 PM
i aint trying to level it i want to make it bigger, i may just save and buy one of those rough country suspension lifts
Old Oct 12, 2008 | 08:00 PM
algranger's Avatar
you could wave bye bye to your approach angle
can you elaborate?
Old Oct 12, 2008 | 08:03 PM
Mic09dcsm's Avatar
200$ is cheap, compared to most other trucks your '85 could easily get 5" with under a grand and up to 8" if you don't mind body lifts. And this is without blocks.
http://www.marlincrawler.com/htm/suspension/springs.htm
http://store.summitracing.com/egnsea...839049&NeXID=5
Old Oct 12, 2008 | 08:04 PM
algranger's Avatar
t_boneshacone:
if i were you i would buy some of those chevy springs, ditch your blocks, throw those chevys under the rear and put your rear springs up front, this will give you quite a bit of lift.
im trying to buy a lift here too and i was gonna get rough country cause theyre cheap but i decided on pro comps for a little more. the rough countrys ride like crap, dont handle any weight, and dont flex worth a damn. my advice, dont get cheap stuff.
Old Oct 12, 2008 | 08:05 PM
881stGenRunner's Avatar
it would move the front axle farther back. because of the center of the spring being so far back instead of under teh fenders
Old Oct 12, 2008 | 08:06 PM
algranger's Avatar
can you elaborate?
well if your replacing your 46" or 48" springs with 63" ones, you will need your front hangers waaaaay out there to keep your axle in a reasonable place, youd be able to see the front hangers from in the cab!!
