Sponsored by: CARiD
92 22RE engine Problems ROUGH IDLE
Old Sep 16, 2008 | 08:25 PM
BAMF_3521's Avatar
Exclamation 92 22RE engine Problems ROUGH IDLE
I just bougt a sweet 92 toyota pickup. It needs some engine work, but cosmetically its the one i've always wanted. Heres the problem:
The engine idles rough almost to where the engine wants to shut off.
The engines vibration is a little excessive.
I took my truck into the shop. All that was done was New Spark Plugs, distributor cap, spark plug wires. The mechanic said i had low compression in one of the cylinders. How can i adjust that? and I supposeably have a vacuum leak on the intake manifold gasket. Im reaching out to the Net because that ripoff dude wanted to charge me 1050.00 to "fix it for sure" I just dont want to deal with that. Does anyone have any advice/step by step?
Old Sep 19, 2008 | 11:45 AM
stagger_lee's Avatar
Hate to say it, rough idle could be a head gasket getting ready to go. What cylinder has low comp? Do you see any leaks or sign of HG letting go? Mileage?
Old Sep 19, 2008 | 12:26 PM
yodercrawler55's Avatar
yea my yoda was idling rough fo a few weeks then a week later the head gasket went out
Old Sep 19, 2008 | 12:50 PM
I only speak from experience myself. Thank God you only have one head.
Old Sep 23, 2008 | 08:48 PM
BAMF_3521's Avatar
Ok so. I was elbows deep for 2 days. Had a Fire. I replaced my intake manifold gaskets, some new vacuum lines,re-insulated some burnt wires, teflon tape to my banjo bolt. Fired her up and She purred like a kitten. my fire jacked up my throttle cable so im waiting for the one i ordered. other than that i just tore apart the inside. gonna reupholster the bench seat and put in a new carpet. freakin sweet.
Old Sep 24, 2008 | 12:34 PM
Nice job. Sucks about the fire. So now if its starts in with a rough idle you know it has to be the head gasket. You gone through just about everything else.
Old Sep 25, 2008 | 07:15 PM
BAMF_3521's Avatar
yea. i will keep the head gasket in mind. Hopefully it doesnt happen/!
Yont283
Sep 23, 2022 08:06 PM
JF9243176
Oct 8, 2017 04:21 AM
Alex Bessinger
Jun 28, 2015 10:05 AM
JF9243176
Jun 24, 2015 04:53 AM
Skydigger
Jul 1, 2002 12:39 PM
