How much do Bj spacers cost and!!!
they dont cost much go to 4crawler.com sway bar is a flash to take down with the right tools. i wouldn'd go more than 1.5 inch lift with bj's spacers ,unless you want to watch your cv joints tear up in a month or less.theyre not that hard to install its just the fact that you have to cut some of the metal underneith the upper a-arm,check out 4crawler its all in there.
and ho i almost forgot,make sure you got some manual hubs!!! really helped my cv's
And Yeah i looked at 4crawlers there not expensive at all. and my Uncle is a Welder and my Dad is a construction worker. Lol both have every tool i can dream having.
I'm probably going to do thatI want to add chevy springs and get me a inch of two taller and a little more flex. but idk. i have Air bags with Coils around them in the back. But i wanna take out the Air bags and replace tem with Chevy SPrings.
What you think?
Switching to Manual hubs is so easy a monkey could do it. I say Go ahead and buy a solid front axle from an 80's toyota PU from the local pick and pull since you are going to do a SAS any way. Take off the AISIN locking hubs off and put them on what you have now. Then when you SAS it you just swap them back to the solid axle.
When you SAS it you should be different and do a front 3link on Coils. That would be sweet!! Just my opinion though for what it's worth. Not and expert by any means.
Putting Chevy Springs in a 4-runner with coil springs is going to be a bit more work that if it had leaf springs to begin with. Unless you are up for it. I notice that a lot of people are going with 3link for superior flex and running tall coils. You may want to go that route so less stuff you have to cut off and weld on. Maybe even try coil overs. Just a few thoughts.
Im saving up 1200 to do all the SaS job and get Red Manual locking hubs to match the Truck
When i do that im switching to Black rims with the Red line around the rim.
And im either going to after i SaS it 5inch lift it and put chevy springs and maybe even do coil overs idk about that yet. working on it.
Please do a search for these types of questions before posting.
This topic has been covered a lot.
We're all more than happy to help out - but we need a little bit of help from you first.
Fink
Fink
Ummm.... The manual hubs from a solid axle will NOT fit your IFS axles! Longfield sells the inners that will allow you to use your IFS manual hubs on a solid axle though. The solid axle and 86-95 IFS manual hubs are not the same!
thanks man.
FS[MidWest]: 1.5" ball joint spacers
4x4YOTA
Aug 23, 2016 09:08 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
4runnerFireman
Sep 29, 2015 06:24 AM
FS[SouthCent]: TX - 4Crawler Ball Joint spacers
crash813
Sep 27, 2015 07:15 AM
