Sponsored by: CARiD
Where exactly is my speed sensor?
Old Oct 15, 2008 | 05:40 PM
BAMF_3521's Avatar
i dont even know where to start and find this sensor? any help>?
Old Oct 15, 2008 | 06:05 PM
jason191918's Avatar
http://www.ncttora.com/fsm/1993/brak...13generald.pdf
Old Oct 15, 2008 | 06:17 PM
BAMF_3521's Avatar
awesome thanks.
Old Oct 15, 2008 | 11:37 PM
anotherjeff's Avatar
...or this speed sensor...
Old Oct 16, 2008 | 08:35 AM
I was lookin for that one...did you want the speedo sensor or the abs sensor?
I showed the abs one, jeff showed the speedo one.
Old Oct 16, 2008 | 08:40 AM
BAMF_3521's Avatar
im not sure which one i need. my speedo and odo is out.
Old Oct 16, 2008 | 08:43 AM
That would be the speedo sensor, the one that jeff pointed out. It could also be a problem in the instrument cluster. I would check the connection that jeff pointed out and look for corrosion/loose connection. If it looks good, i'm not sure how you can tell if the problem is the sensor or the cluster.
Old Oct 16, 2008 | 08:46 AM
http://www.ncttora.com/fsm/1993/body.../6combinat.pdf
maybe this will help?
Old Oct 16, 2008 | 11:03 AM
You'll need to verify the type of speedometer drive on your truck. It could be the conventional cable, or electrical sensor. '92 seems to be a sorta crossover year. Crawling underneath and observing, is probably the best bet here.
Jason is right about difficultly in isolating problems with the electrical sensor type speedometer. Trial and Error gets $pendy with non-refundable electrical items.
Do you already have the tach-cluster upgrade? If not, maybe it's a good time to swap, and see if the new speedo works? If not, it must be the sensor, hey?
...and, don't you really mean I4, instead of v4?
krimsonone
Sep 13, 2024 09:33 AM
montanatruck
Feb 26, 2017 07:07 AM
ty1er
Aug 1, 2015 11:53 PM
wilbertd
Jul 6, 2015 07:39 AM
karbin
Jul 5, 2015 11:37 PM
