Sponsored by: CARiD
help me ID this part
Old Oct 10, 2008 | 06:23 PM
mud junkie's Avatar
Found on the top of the valve cover of the 22RE it has an electrical connection and 3 vacuum lines comming from it. just behind and to the right of the oil cap.what is the technical name for it? mines broken
Old Oct 10, 2008 | 07:15 PM
4Crawler's Avatar
Probably one of the several Vacuum Switching Valves (VSV). See what it connects to to figure out that is does.
Old Oct 10, 2008 | 08:38 PM
aviator's Avatar
check the online FSMs through our links in the maint. section to get an idea.
Old Oct 12, 2008 | 04:54 PM
mud junkie's Avatar
thanks guys,
I looked for it and still cant find what the technical name for it is. Ill do some searching and see if I can find it. it might be why the CEL is on. I did the code thing with the wire and got a lot of blinking. I tryed to decipher the code messages but Im not good at morse code. when I get my video OK'ed with you tube Ill post it up to see if anyone can help me on the code guessing game.
Old Oct 13, 2008 | 09:50 AM
aviator's Avatar
Yeah a pic of the part would help a lot there are a lot of VSVs and junk in that area.
Old Oct 13, 2008 | 05:13 PM
mud junkie's Avatar
I took a pic of it but I think its too big,Im new to this computer stuff. its a size 640x somthig I think.
Old Oct 13, 2008 | 08:28 PM
EvaMonky's Avatar
Get a photobucket account, upload it to that, then use the link from there to post it here.
Then we can all see it easily.
Old Oct 14, 2008 | 03:44 AM
mud junkie's Avatar
ok I think I got it,Heres the link to the pic
its the senor just behind the oil cap to the right.
http://i461.photobucket.com/albums/q...IMG_0001_2.jpg
Old Oct 14, 2008 | 03:45 AM
mud junkie's Avatar
heres the link
Old Oct 14, 2008 | 03:46 AM
mud junkie's Avatar
Old Oct 14, 2008 | 04:18 AM
mud junkie's Avatar
just behind the oil cap to the right,what is that?
Old Oct 14, 2008 | 12:51 PM
aviator's Avatar
Ok so I took a look at the ToyoDIY.com website and the parts # listings and diagrams and as near as I can tell that is one of the vacuum switching assemblies. That is my best guess though there I can find no whatever it is shown exactly like that in the diagrams. It seems to be missing some vacuum lines if this is what it is and you do have that line strangely capped off beside it in the pic. Don't quote me on that but it would be a place to start.
Hope this helped a little
Aviator
Old Oct 14, 2008 | 02:30 PM
mud junkie's Avatar
yeah I got it like this so I dont know what was there or why it was capped off. maybe I need to go to the junk yard and pull one off another truck if they dont make another one for it.
Old Oct 14, 2008 | 03:30 PM
4Crawler's Avatar
If you have A/C, that is for the fast idle when the A/C is on:
http://www.4crawler.com/4x4/CheapTri...ine_Pix/1.html
Old Oct 14, 2008 | 08:14 PM
aviator's Avatar
Hey 4crawler
that def. looks like the part on his engine but it is missing a lot of bits and pieces... the vacuum line attachments and that black cylinder thingy on the end... looks like a trip to the yard is in your future mud...
Old Oct 14, 2008 | 08:28 PM
4Crawler's Avatar
The black cylinder thingy is just a little air filter over the vent line. It is a little plastic cap filled with felt that slips over the vent line to let in clean air to let the idle up valve close when not needed. But yes, there should be 3 vacuum line fittings on the VSV, one for incoming vacuum, one for the vent line (that the cap fits over) and one that is the outlet line that hose to whatever the VSV is actuating.
Old Oct 16, 2008 | 04:23 PM
mud junkie's Avatar
Yeah a trip to the junk yard is comming up soon. thanks for all the help trying to find what that was. I bought the truck last week for $1000 and its in really good shape. I got it legal and have been driving to work and to the hunt camp this week. I work 74 miles away one direction. it runs really good but it has some problems. the major on is the guy I bought it from didnt tell me much about it. He swapped the dash out for a dash from an SR5 so half the gauges dont work. the volt meter aand the temp gauge are the only ones that work. the oil pressure guage is INOP so it the fuel gauge (I think its a sending unit on both) the tach jumps all over the place and the speedo reads way off. other than that the brakes need to be changed, and new battery terminals and a few new bulbs here and there its all complete. The Air conditioning was eleminated so would I still need that part? the biggest concern is the dash cluster. do you think new sending units would fix that problem or is it the dash being off another model?? the other problem is the tach,what would make it jump all over the place like that?
thanks for the help guys the wife hates me on the internet all the time but I find alot of use full info on here.
88sasturbotoy
Jan 30, 2026 01:57 PM
May 20, 2016 10:27 AM
Fundy Rider
Jul 16, 2015 01:35 AM
akaphilly
Jul 9, 2015 02:34 PM
