Sponsored by: CARiD
question about torsion bars
Old Sep 1, 2008 | 08:57 AM
barrelrolldougie's Avatar
ive got a 91 4x4 truck, when i bought it, it had a smitty bumper on the front that i took off and replaced with a stock one. so my truck rides like crap, like feels alot worse than i think it should, so i looked under it and the torsion bars are cranked up all the way,no more thread visable on the nut. But the truck is completetly level front and back, if the tbars were cranked all the way wouldnt the front be higher than the back? Baisicly now that the bumpers off id like to uncrank the bars a bit, but if i do will the front sit lower than the back? thanks
Old Sep 1, 2008 | 09:05 AM
AxleIke's Avatar
if you uncrank the bars, you will get a smoother ride.
You will drop the front end.
A possibility is to put in ball joint spacers, and then relax the torsion bars down a bunch, so the truck sits level again.
Old Sep 1, 2008 | 10:56 AM
thats what i was thinking, what happened though did my torsion bars go bad or something? were they cranked to high too long and now they wont relax or something?
Old Sep 1, 2008 | 02:16 PM
bigarms23's Avatar
they could be toast so get a replacement set from rancho or downey
Old Sep 1, 2008 | 07:42 PM
AxleIke's Avatar
Downey or rancho are going to be horribly stiff unless you have a heavy winch and bumper.
Old Man Emu makes a set that is a little stiffer than stock, but not nearly as stiff as the rancho/downey set ups.
Old Sep 2, 2008 | 06:55 AM
mt_goat's Avatar
Lets see a pic of your front a-arms. I had a friend that made the same complaint, when I looked at is front end I saw he was almost sitting on the bump stops. Everytime he hit bumps on the road he was smacking the bump stops.
Originally Posted by barrelrolldougie
....i looked under it and the torsion bars are cranked up all the way,no more thread visable on the nut.
If your t-bars are fully cranked you should see lots of thread at the top.
Old Sep 2, 2008 | 01:48 PM
yea the bars are just definetly cranked up all the way, the head of the bolt is touching the bracket the bars connected to, the arms dont look too close to the bumpstops. Thanks for all the help with this stuff from everyone, this is my first 4wd, all my trucks before this were either bagged or bodydropped, so all the info on this site is a huge help. i dont post often, but i do read it about everyday. thanks again everyone for all your help
4.34runner88
Aug 11, 2018 10:44 AM
andrewtexas123
Jul 6, 2016 01:49 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
coffey50
Jul 28, 2015 10:55 AM
DrZero
18
Jul 24, 2015 11:31 PM
