Sponsored by: CARiD
I want to do a 2x4 to 4x4 conversion
Old Oct 14, 2008 | 07:09 AM
grizzlypaugh's Avatar
Well i have a 1990 toyota pickup reg cab, with a 22r 4speed, manual steering, so this is what i think i will need, A solid front axle, front driveline, rear driveline, transmission t case, now i would want to do a powersteering conversion and need to know what i would need for that? and was wondering if i need a 4x4 oil pan? will i need a rear axle? and should i do a coil over suspension or just leafs?
Old Oct 14, 2008 | 08:18 AM
tc's Avatar
tc
It would be SO much easier to just sell the 2WD and find a good 4WD.
Old Oct 14, 2008 | 08:21 AM
thanks that was what i was thinking haha.
Old Oct 14, 2008 | 09:01 AM
trbizwiz's Avatar
I dont know, if you wanted an extreme rock crawler, you would replace most of the factory stuff with upgraded stuff anyway. You would definately do a sfa, and probably do stuff to the transfer case and tranny, with geaing and such. If you just want a factory quality 4x4 though, just go buy one. You can probably steal a 4runner right now. I have seen several 98's for $4500
Old Oct 14, 2008 | 09:23 AM
kev's Avatar
kev
You will need to change the oil sump and pan. I believe there are some differences in the heater hose assembly
Old Oct 16, 2008 | 11:19 AM
Johannes's Avatar
I'm with getting a new vehicle.
Apart from some nostalgic value or just a challenge, unless you have the time, motivation, tools, and most importantly $$$$, then it's going to be one hell of a project.
I've seen too many people start a project like this get discouraged along the way and end up tearing the truck apart, then selling it for a third of what it's worth.
If you're serious about it, at least get yourself a cheap 4x4 for reference and something that you can drive while you're working on the project, it's hard to know your friends are getting muddy while you're turning a wrench.
Old Oct 16, 2008 | 12:22 PM
bigtrucknwheels's Avatar
I agree.
but I also agree that if you are making it a full-out crawling machine, it really doesn't matter what the base vehicle is.
Old Oct 16, 2008 | 12:40 PM
zlathim's Avatar
X3!
Unless you are wanting a long labor intensive and expensive project, just buy a 4x4. You could build it up while daily driving the 4x2.
Old Oct 17, 2008 | 12:47 PM
santacruz77's Avatar
ill trade you a 85 4x4 with a bad motor and a grand for yours haha
Old Oct 19, 2008 | 09:53 AM
Cargun's Avatar
Depending on how you want to build it, a 2wd makes a great start. The only difference between a full out build on a 85- or 86+ 4x4 and a 2wd truck is sourcing the transmission/t-case, cross member, driveshaft core, and rear axle swap. Pirate had some info on the 2wd frames noting they retained the 85- frame hump which is more SAS friendly than the 86+ 'flat' front frame section.
Suspension and steering is all redone anyhow, so it really doesn't matter what you start with. (Other than the 4wd front fenders and grill look better)
If you're looking for a milder build (one in which you'll retain some of the factory setup), it's easier/cheaper to start with a 4wd.
coleypull15
Nov 3, 2015 07:41 AM
PNWrider
Oct 30, 2015 08:14 AM
defrag4
Jul 31, 2015 10:50 AM
PopsDad1
Jul 30, 2015 02:21 PM
pyramid
Jul 29, 2015 06:53 AM
