Sponsored by: CARiD
Squeeling noise at idle.
Old Oct 1, 2008 | 06:46 PM
LukeWilson's Avatar
Hi all,
I am new to the toyota truck world, i just picked up a 1990 22re extended cab 4x4 with 95000 miles on it. Its really clean and extremely well kept, everything is stock though (soon to change). However i just encountered my first problem. When i first got it the PO said that new belts were put on 200 miles ago, at higher rpms they would squeel really loud. I tightened the fan belt and the squeel at high rpms went away but now i get a pretty loud squeel at idle. I am thinking that it is a bearing because the increased tension would expose the problem. it will go away as soon as your off idle and then come right back. I just wanted to double check this and maybe get some ideas as to which bearing it may be?
Thanks,
Luke
Old Oct 1, 2008 | 10:38 PM
fillsrunner4's Avatar
Originally Posted by LukeWilson
Hi all,
Thanks,
Luke
spray belt dressing on the belt at idle and see if it fixes the sound for the moment. Sounds like belt!
Old Oct 2, 2008 | 11:24 AM
LukeWilson's Avatar
Tried that already, it didn't make any difference.
Thanks,
Luke
Old Oct 5, 2008 | 09:48 AM
myyota's Avatar
Im having the same problem with my 86 4Runner, and ive traced it to the idler pulley bearing.
Old Oct 10, 2008 | 07:07 PM
baseballchamp157's Avatar
did you think about the altenator belt?
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
Chicken12
Oct 14, 2015 03:54 PM
creecher10
Sep 30, 2015 03:27 PM
