Sponsored by: CARiD
Idle issues 92 4runner
Old Oct 22, 2008 | 04:59 PM
jaysonbraid30's Avatar
1992 4runner Medalist. 3.0 litre. 153,000
Idles high at 1400 while cold. very slowly drops to 11-1200, until heat gauge registering half for at least 20 mins of driving. Then settles at 700ish.
Any ideas why it idles so high for so long past warm?
thanks.
Jay.
Old Oct 22, 2008 | 05:43 PM
4Crawler's Avatar
Might be a bad temperature sender for the ECU. That sender is separate from the sender for the gauge.
Old Oct 22, 2008 | 07:58 PM
Ok, idea on how to diagnos if sender is bad, or replace it? thanks.
Old Oct 22, 2008 | 08:31 PM
4Crawler's Avatar
A Factory Service Manual would have the testing procedure. Usually consists of measuring sender resistance at a few temperatures to see if that matches the factory specs for the part. Might also be a similar issue with the cold start injector and it's temperature sending unit or with the cold idle air bypass valve.
Old Oct 30, 2008 | 06:26 AM
Thanks I will try this and post results.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
CJ94yota
Jul 3, 2015 10:14 PM
