Sponsored by: CARiD
door buZZZZer!!!!
Old Sep 26, 2008 | 07:06 PM
92yotapickup604's Avatar
door buZZZZer!!!!
Ok, how do u disconnect the door buzzer on a 92 yota pickup without having to disconnect the auto-door light?? I cant seem to find just where the buzzing is coming from to disconnect it at the source so i unplugged the 1 red wire which connects the light and the buzzer switch to the fuse box.
Please...
much appreciated
Old Sep 26, 2008 | 07:19 PM
ozziesironmanoffroad's Avatar
there should be a big black box under the dash with a tiny speaker on it... disconnect it. at least thats where it is on mine...
Old Sep 28, 2008 | 12:20 PM
The wire comming out of the censer leads behind my fuse box under the dash, could it be built in the beige fuse box????
Old Sep 28, 2008 | 02:14 PM
Trustyrusty's Avatar
Open your door, it will buzz, crawl under the dash and look near your clutch arm you'll see a black box, push it towards the drivers side and it will slide off of its bracket, un plug it, use a screwdrives to pry off the opposite end, then push out the circuit board, there'll be a wierd little thing with some copper wire wrapped around it and an arm that touches another one, bend it flat to the circuit board, re-intstall, and no more buzz, hooray. Now get yourself a beer. Don't be pissed at me if you lock your keys in your truck some time, but its sorta impossible cause when you shut the door even if its locked it unlocks so who cares...
Old Sep 28, 2008 | 05:20 PM
scuba's Avatar
I used to have an 86 that did that, my new 91 doesnt, so my assumption is they stoped it when they made the 3rd gen p/u's
i hated and loved that features, friends would never be able to figure it out..lol
Old Oct 5, 2008 | 03:14 AM
anotherjeff's Avatar
The actual buzzer in located on a circuit board within the Integration Relay, which is located behind the fuse block on the driver-side kick panel. After loosening the fuse block, the Integration Relay can be removed and taken to the bench, where the covers are removed to access the circuit board. The buzzer will be apparent, and can be de-soldered from the board. Put everything back together, and the efffffing buzzing is GONE! Worked for me!
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
JamesDINAN
Sep 22, 2015 05:37 AM
