Sponsored by: CARiD
Loss of power
Old Oct 16, 2008 | 04:51 PM
joehill's Avatar
Loss of power
ok so here the deal. I think this started noticing this about a month ago. basically I have no power up hills. I mostly have noticed this in the morning on my way to work. as soon as I get on the high way my 90 4runner wont accelerate. Ill have the gas pushed half way down and the tac will sit at 2500 rpms and im going about 35 mph, if I push it further it will rev to 3000rpm but instead of going faster it slow down, eventually after driving long enough it drives normally. I also noticed this is more of a problem when its cold or the engine is cold. what could be causing this? btw I recently had to replace the cat because it was stolen of my truck but i dont remember if this happened before or after i started having this problem
Old Oct 16, 2008 | 05:30 PM
bigarms23's Avatar
is your 4runner stock or lifted and if lifted what size tires
Old Oct 16, 2008 | 05:35 PM
joehill's Avatar
every thing is stock
Old Oct 16, 2008 | 05:41 PM
camo31_10.50's Avatar
i have the same problem but mines an '86 pickup and its carb'd...as long as my motor is warm it runs fine..but if its cold..i have no power..lol..
Old Oct 16, 2008 | 05:53 PM
904_runner's Avatar
to the op, unbolt the flange on the front of the catalytic converter. just enough to cause a fat exhaust leak. it will sound like garbage, but see if it runs better.
you may have a plugged cat.
that is what happened to mine, it started losing power gradually till i got it figured out
Old Oct 16, 2008 | 05:58 PM
joehill's Avatar
well when the original was stolen they cut it out. so the new one was welded in
Old Oct 16, 2008 | 06:16 PM
904_runner's Avatar
bummer
Old Oct 16, 2008 | 06:27 PM
myyota's Avatar
When was the last time you replaced the fuel filter ?, that can and will cause a loss of power if its plugged.
Old Oct 18, 2008 | 03:54 PM
joehill's Avatar
i have had it for a year and a half and have never changed it.
Old Oct 22, 2008 | 08:23 PM
bigarms23's Avatar
after a reread it definately sounds like you fuel filter
Old Oct 27, 2008 | 02:52 PM
joehill's Avatar
well im going to take it in tomorrow, now that its getting cold up here in the twin cities its gotten even worse. nd on top of that there is a poping niose that goes along with it.
Old Oct 30, 2008 | 04:28 PM
joehill's Avatar
took it back to midas to check the cat. they said that was fine. the thought it might be the fuel dampener or the timing. when they did the tests they found nothing. took it home and today after work it died on me twice and then the battery was dead also. i have a new battery and alternator. so i have no idea whats going on.
Old Nov 6, 2008 | 03:11 PM
joehill's Avatar
how hard is it to replace the fuel filter? would doing one of those fuel system clean outs the sell and the oil and lube places help?
Old Nov 6, 2008 | 03:47 PM
swaycleveland's Avatar
vacuum line!
check those. i forgot to hook one up after tinkering under the hood drove me up a frigin wall till i saw it unplugged. hooked up reset computer PERFECT!
Sleaker
Aug 26, 2020 06:03 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
Tacoma1313
Aug 17, 2015 05:44 PM
nate2919
Aug 6, 2015 04:00 AM
gmonnie123
Jul 26, 2015 02:44 PM
