Sponsored by: CARiD
Steering, bad noise when turned fully right,linkage groaning
Old Oct 22, 2008 | 12:20 PM
shaun's Avatar
86 4runner all stock, tires31 10.5 15 (210,000 and I am the only one to ever do anything with it, original shock was my first clue)
Okay first off, I don't know the first thing about the steering linkage. So, here is what happened. I came out of a parking lot, and had to turn the wheel all the way to the right to make the street and then dipping into the gutter the front end made a sound. It was kinda of like a quick groaning sound, not quite a pop, but close. Afterwards it still drove and steered correctly. Near my house I again turned it all the way to the right to see if it was just the steering, as I was on level ground and it did the same only milder, because I expected it and don't want to damage anything.
What do you think the culprit is or could it be a host of problems.
Old Oct 22, 2008 | 12:31 PM
4Crawler's Avatar
Might check the steering stops:
http://www.4x4wire.com/toyota/mainte...ront_end/lube/
Old Oct 22, 2008 | 12:41 PM
g_mau18's Avatar
Almost every toyota i have been in and even nissan pickups make a gnarly sound when fully turned to the right. Its a super common problem and there are dozens of topics in this forum on this............search man.
Old Oct 22, 2008 | 12:46 PM
904_runner's Avatar
x2, the plastic caps probably finally broke or fell off.
Old Oct 22, 2008 | 12:55 PM
shaun's Avatar
Okay thanks all. That is what the problem was/is. I just got worried, with a sound like that.
BTW I did search, just didn't have the right combo of search terms. Sometimes I try to search and forget the obvious "steering noise", off course It helped more after I stopped searching for stearing.
Anyways found the "old" thread(s) with more links.
https://www.yotatech.com/forums/f2/s...ictures-33559/
Old Oct 22, 2008 | 01:16 PM
904_runner's Avatar
When i first got my toyota, that made me wonder! But now you know and you can pass on the knowledge!
Old Oct 22, 2008 | 06:25 PM
shaun's Avatar
Okay so i figured I would post this. After reading the other thread I rubbed some moly grease in there and the noise stopped. I am on a budget so there is more pressing matters to attend too. I will be picking up some groan stoppers or plastic caps in a future time.
Thanks again.
Old Oct 22, 2008 | 06:39 PM
jason191918's Avatar
My dad always tells me my truck is going to fall apart because of that noise...he doesn't get it...
kazuya2416
Apr 5, 2024 02:17 AM
razorman8669
Jul 12, 2015 12:13 PM
jon.r
Jul 11, 2015 03:34 PM
smiley52
Jul 11, 2015 05:16 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
