Sponsored by: CARiD
Dang Hydrocarbons
Old Sep 5, 2008 | 10:26 AM
DWEINBERG01's Avatar
Dang Hydrocarbons
So I took my 4runner in (again) to see if it would pass smog. The results were much better , but it still didn't pass bacause my hydrocarbons were too high. Here is a picture of my results.Any idea how to get these stupid things down to a reasonable number without tearing the motor apart again?Thanks
Old Sep 5, 2008 | 11:29 AM
4Crawler's Avatar
Fresh oil and PCV valve in the engine? If not, do so.
High HC is too much fuel or not enough air. Make sure air filter is clean. Then O2 sensor is working, it is a Denso and not a Bosch sensor, right? And if all that is OK, a new cat. will help a lot.
Old Sep 5, 2008 | 02:56 PM
Okay, it is a brand new air filter, maybe 40 miles on it, and I already put a new cat on it. As a matter of fact, it is a Bosch o2 sensor. Does Bosch suck or something or does it give off the wrong signal?
Btw you have just given me more info than my local dealership would without me paying $90 for a diagnostic test. Thank you for at least giving me a place to start. You
Old Sep 5, 2008 | 03:06 PM
4Crawler's Avatar
Bosch and many other O2 sensors do not have a long enough sensing tip to get into the exhaust gas flow on the Toyota exhaust like the longer tipped Denso sensors. A real Denso sender is not that much more expensive than other brands:
http://www.sparkplugs.com/
Bosch parts work excellent on German made vehicles (that is all I use on my VW), but on Toyotas, Denso parts seem to work the best.
Redeth005
Jun 28, 2018 08:16 PM
bootscootboogie
Sep 5, 2015 05:57 AM
scooterpie01
Aug 28, 2015 10:15 AM
Duppie007
Aug 20, 2015 04:39 AM
Sidherish
Aug 3, 2015 07:17 PM
