Sponsored by: CARiD
Driveshaft question
Old Nov 2, 2008 | 06:46 AM
DWEINBERG01's Avatar
Driveshaft question
I couple of months ago, I removed my rear drivshaft. When I did, I forgot to mark the holes so I could put it back in the same way. When I pulled it out the yoke seperated and I just stuck it back together. Now when I drive it under load i.e. 4Lo and climbing, the drive shaft flange on the t-case end grinds on the horse shoe that holds the t-case shift linkage.
I am going to take the shaft to a shop and have it balanced because I think that is half the problem. My question is: How do I figure out the original mounting position (matching the original holes together)so I am not causing any damage to the case or the shaft?
Old Nov 2, 2008 | 06:49 AM
4Crawler's Avatar
http://www.4crawler.com/4x4/CheapTri....shtml#Phasing
Old Nov 2, 2008 | 06:54 AM
Thanks 4crawler.
Old Nov 3, 2008 | 10:03 AM
So I followed the guide given by 4crawler. My joints were, uhhhh, way off parallel. I straightened them out and took it out for a test drive. It didn't grind as much, but it still jumped out of gear, mostly under load when bouncing (I know that is not good, so I try to avoid bouncing.) When I got back, I again looked underneath and saw a large rubber square with a bolt in it.
If you look on this picture there is a bracket where the torsion bars used to be.
There are also several bolt holes in the bottom of the cross member in fromt of the transfer case. My question is: is there supposed to be a support right there under the rubber piece to support the t-case from bouncing? If not, then I am guessing that there is something wrong with the case
Old Nov 3, 2008 | 10:17 AM
4Crawler's Avatar
Not sure what that block is for, maybe some sort of vibration dampener or something. In the upper picture, you can see your t-case mount bolted to the sides of the case, the two shiny bolt heads in at an upward angle. Should be two similar bolts on the opposite side and typically 4 smaller bolts in through the bottom of the cross member to hold the t-case mount down. Check the rubber in that mount for tearing and also check your two motor mounts up front.
Old Nov 3, 2008 | 05:33 PM
Good Call 4crawler
So I checked the mounts under the transmission (motor mounts are brand new with about 5 hours of light off road use on em' so I figured those are good). I dropped the crossmember and removed the mount from the t-case. It felt a little sloppy, and I did see some cracking around the outer edge. I removed the large bolt in the middle and this is what I got:
Gonna buy a new one tonight and see if that helps stop the t-case from slipping out of gear and bouncing.
4x4-runner
Apr 18, 2017 09:08 PM
mussy01
Dec 13, 2016 08:20 PM
Tonetrk
Aug 6, 2015 10:06 AM
gillesdetrail
Aug 3, 2015 04:43 PM
Sr5crawler
Jul 31, 2015 12:32 PM
