View Full Version : Newbie Tech Section
- DTE /AVG MPG / Outside temp unit on the lexus and higher end Toyota's
- Swapping out Steering wheels
- Lying low in the back, is there an easy fix.
- parts interchage - blower switch and dimmer
- 84 pick up carb question?
- Pros & Cons of installing a Body Lift on an offroad 4x4 truck
- 1992 v6 wont start.
- sas
- 5th or 2nd/3rd gen?
- 4.56 diffs
- 1998 4Runner Keyless Entry
- T-stat housing bolts
- replace or rebuild???
- 87 22r in need of carb.
- k&n issues-please help!!
- Toyota Master Tech selling a 2nd Gen S/C for $1000 installed
- Ticking in engine
- spacer lift with TRD coils
- Welding, steps to prevent electric damage
- 1984 Toyota Pickup Timing Chain Replacement
- 4th gen truck bed
- Blue Loctite pressure plate to flywheel?
- 97 4runner floor shifter
- 1999 4Runner Idle Question
- oil pickup? I think its called??
- How to test if starter is good
- 97 4Runner shifter
- Door lock actuator replacement
- 1st Gen truck alternator over charging
- thunking noise??
- ext cab windows do not open
- 3.0 head bolts
- alternator over charging
- *sigh*,I hate to ask this,but...
- Inerpreting Ohm Meter Reading on TPS test
- Lift vs Spacers and Other Info
- 97 4Runner maintenance questions
- Toyota lift kits
- how high does your truck sit with X lift
- CV Boot? Stumped....
- Question
- campershell
- power steering problem
- Where is the Firewall
- rim specs
- rubbing when fully turned?
- V6 VS. V8 maintaince? Common Issues. Towing Capacities. 3rd row seat
- Do I Need This????
- 3rd gen front suspension
- winshield on a '91 truck
- Auxillary Transmisson Coolers
- cold trans prob on 90 4runner
- HO Alt from Mr. alternator
- Will not shift into overdrive
- 2000 4runner lift HELP
- starter change?
- sas kit opinions
- Newbie questions - 98' T100
- 92 4runner how to open tail gate from outside?
- Cooling line stripped?
- "normal" operating temp on the 22RTEC?
- Looking for Advice on Maintaining a recently purchased 1993 4x4 v6 truck.
- 2nd&3rd generation Toyota's ?
- Newbie Hello & Super Noob questions...
- Why do fuses blow?
- Project Yota Rebirth
- 2wd donor for 4wd? HELP
- I am a newb to this forum.
- replacing front shocks - help
- VIN breakdown
- How to lift front
- Noobie Question of the Day "What is the ETC Button"?
- 2000 4runner bumper modification
- 93 4-Runner pump change out
- got gears?
- Metallic Clicking
- 3vze???
- how tight do i tighten main bearing and rod bearing
- locker-spool
- Few 4runner Q's
- 4 runner --> truck
- Second Opinion?
- 90 4runner wont start
- 4" Suspension Lift on 97 4runner
- how do you tie your toy down?
- 99 4runner SR5, have specific questions, please give me advice
- newb body lift- what do i need?
- 94 4runner 3.0 cold/warm start issue
- Buying a Tacoma bed
- Can I get some clutch recommendations?
- New pickup: Mods to come
- is it the same as a Toyota
- 94 toyota xtra-cab
- my 89 up for SAS ?
- to cut or not to cut?
- what gears?
- trying to install new cam please help!!
- Harmonic balancer seating correctly?
- i sawped a 3vz-e into a 1985 4Runner
- how many 1985 Toyota 4Runners
- Runs bad
- 87 4runner dropped pitman arm
- 22re timing cover
- want to put 4.56 gears and front locker in my 07 taco
- lockers???
- cleaning engine compartment
- Longer coils causing strange noises?
- will a 4 runner drive shaft fit a t100 if it is the same year and has three joint sys
- what kind of aftermarket steering wheels for 1st gen 4runner?
- 4runner 1.5" IFS lift
- CV joint question
- Broken birfield - Need Help
- 22re over cooling issues
- Do round/pear shaped heads share bolt pattern?
- Want to Pull Out Engine ONLY...!!!
- Ups and downs of a sas.
- Factory service manual 86 22ret
- Gear driven case behing auto?
- starting problem
- 99Runner - tie rods seized??
- 99 Runner Limited - AC recharge
- toy pickup- cheap tailgate?
- Cylinder Heads International?
- Are T100 t-cases chain drive?
- motor question
- still jerky, sluggish accel and idle
- Temp Guage Moving Rapidly
- what size lift?
- Help Dad's 1997 runner needs an engine!
- 91 Pickup part hauler -- axle and suspension modification
- KNOCK SENSOR WIRING TROUBLE 88 6cyl PU
- 1988 Toyota 4x4 Pickup 6 cyl 5 speed HELP
- What does isr mod mean and whats it do
- 3rd member question
- is it an sr5 or Sport?
- Help camber bolts will not turn
- 95 4runner 3VZE DTCs?
- Brake Rotors
- 85 22re starter problem
- Need link(s) to Service/Repair Manuals
- Compression Test Results
- 89' Pickup Starter
- Changing oil
- 1993 Toyota 4Runner 3.0L idles rough due to intake
- FJ60 series lifts...
- starter problem
- body lift on 95 4runner with auto trans?
- fuel pump
- 87 FJ60 lift kits
- solid axle conversion
- need help
- w56
- motor???
- can i lift a 2001 tacoma s-runner?
- toyota tacoma jacked up muddin?
- Can't turn all the way going right (bent tie rod or ???)
- 1992 Toyota pickup 22 RE fuel pump question
- Hard to find 3vze parts
- engine swap pregame
- 89 runn SAS w/ dana44?
- 3vze P/S Belt
- 22re engine wiring harness
- Brake upgrade/interchange question
- Good Mechanic
- 95 4-runner V6 3.0 in a 1992 pick up
- knock sensor wire
- Spacer lift???
- What kind of Lifts are there for my 90 runner?
- Newbie looking for font bumper!
- '91 SR5 Tranny
- '91 SR5 Idle Issues
- This truck is going to drive me nuts!
- 1993 Fourrunner engine issues
- Low Idle stalling 22re
- Newbies First Off Road Trip
- Antifreezze for 22re 1995 pickup
- 93 pickup starts then stalls help!
- good trade? bad trade?
- Newbie the great!!!
- Pitman Arm issue
- idler pulley 93 3.0
- 88 4runner engine swap
- Expert Help Needed
- How to tell if 3rd gen 4runner has factory e-locker?
- 86 t100 engine upgrade???
- 2003 4Runner antenna
- 1985 Pickup
- 87 runner in need of help
- Need Help~~>>Tranny Swap...5-speed to Auto
- ECT removal
- 99 4Runner Auto -- Shifter Knob Removal????
- 91' 4Runner Questions
- removing injectors
- Intro to myself (noob) and questions...
- ? About new weber on my 82
- Engine swap options 4.3 Chevy
- Many Questions: 86 Toyota SR5 4WD Extracab related...
- newbie to the site
- My Yota
- Trans ?
- engine running status
- 91 PUP Front upper control arm replacement
- Alternator issues w/'91 4Runner
- Newbie with tech question
- bed liner Interchageability options for 82 p/up
- SO the local Auto shop wants $1,200 for my 90k maintanance service? RIP OFF?
- clutch kit???????
- buying a 4runner...
- 4runner 4wd issue
- what lockers do I want for my 89 4runner?
- Opinions on 4Runner suspension
- Seafoam use?
- Stumbling Idle, new engine, please help.
- Surging RPM with A/C on
- knock sensor
- coolant flush - running without antifreeze?
- 22r Timing problem
- noob here
- front diff problems
- Need to drill out exhaust manifold heat shield bolts. How deep do they go?
- Crazy 1990 v6 4Runner 3.0 fuel injected with a mind of its own
- pan gasket on a 22re
- Will a W56-C fit an 88 4runner
- CA Smog Compliant
- Headache Racks - 2006 Tacoma - Mounting?
- Can anyone help me out?
- lift and tires?
- RAV4 shudder/hesitation during accelleration
- TPS pig tail
- front clearance
- blinker mod screwed me. :(
- Newbie Custom Bumper Opinions
- new to the group, great forum
- Rear Licence plate lights
- 90 4runner lift? suggestions?
- I want to start with the right truck
- Keyless Entry Sequioa 2003
- high CO emission
- Newbie here.. Here is my 99 4runner.. all stock but not for long.
- offroad
- Oil pan problems
- Weak points?
- timing belt or chain????
- newb question here
- Need Help removing A/C evaporator,General A/C help
- stock wheel b/s
- I have a noise coming from my rear end...and its not a fart!!
- 1st Gen Runner Dash Pic - Please
- New here with starter bolt question
- 1st one to say what I am doing in this pic gets a cookie !!
