Sponsored by: CARiD
pan gasket on a 22re
Old May 15, 2009 | 05:41 PM
94toy4x4fever's Avatar
How hard is it to pull the pan off of a 22re while in the truck? Also do you guys use a new gasket or just use some rvt sealent?
Old May 16, 2009 | 09:40 AM
****bump****
Old May 16, 2009 | 09:42 AM
TOYOTA 1's Avatar
use rtv.
the front diff has to be lowered, along with taking off some steering.
Old May 17, 2009 | 08:31 PM
anyone have more details on lowering the front diff in order to get the pan off?
Old May 17, 2009 | 09:55 PM
874runnersr5's Avatar
Alright, all you gotta do is unbolt the thing that the steering stab bolts to..(cant thinkof the part right now) but if your looking towards your truck, it sits on the left side.. its 3 bolts. Then, that'll hang, then there are 3 bolts that hold the front diff to the truck.. get a jack under the pumpkin and get a prybar in to get it out of front bolt bushing area.
tada, lower it really slow. Its pretty easy, a novice like me did it.
Old May 17, 2009 | 10:04 PM
TOYOTA 1's Avatar
the idler arm? i didn't have to take that off.
1. unbolt the front diff mount.
2. unbolt the cross member(4bolts) and remove.
3. unbolt drivers side axel(it makes it easier)
4. unbolt steering relay rod and swing it out of the way.
5. put a jack underneath the front diff.
6. unbolt the top 2 diff mounts then lower the diff.
I'm sure I'm forgetting something but that should get you started.
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
irritech
Jul 27, 2015 05:15 PM
scottyg486
Jul 19, 2015 05:34 PM
ryerye13
Jul 14, 2015 08:27 AM
