Sponsored by: CARiD
fuel pump
Old Jun 4, 2009 | 06:23 AM
rey's Avatar
rey
fuel pump
89 toyota 4 runner on top of the gas tank there two wires a white with black stipe and a solid blue. how do i check to see if there is current coming out of those wires.
Old Jun 4, 2009 | 09:01 AM
UKMyers's Avatar
Moved your thread. An 89 Runner is a 1st Gen not a 3rd Gen. As far as the voltage goes get a voltmeter and stick it into the wire. Heck even a light tester would work. What are you trying to troubleshoot?
Old Jun 4, 2009 | 10:12 AM
scuba's Avatar
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
That might help some (BOOKMARK IT!!), Im pretty sure your testing for power to the pump ? if yes im also pretty sure your gonna want 12V on the blue wire you speak of while the key is turned to the on position.
Good luck let us know what happens !!
Old Jun 4, 2009 | 11:12 AM
eric-the-red's Avatar
The blue wire supplies power to the pump, the white/black is the ground. The blue wire will only have power when the EFI relay and the Circuit Opening Relay are both closed.
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Fundy Rider
Jul 16, 2015 01:35 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
