Sponsored by: CARiD
90 4runner wont start
Old Jun 19, 2009 | 09:04 PM
aldom92's Avatar
Exclamation 90 4runner wont start
i have a 1990 4runner 6cyl that wont start. it was running jus fine, went to the store, then didnt wanna start. it turns over, but doesnt start. it is definitely gettin enough juice from the battery. i towed it back home and disconnected the air box from the throttle body. it looks pretty dirty. i tried starting it without the air box and it almost starts. i tried giving it gas, and there was a small explosion (pop) from the throttle body. any ideas? thanks in advance
Old Jun 21, 2009 | 06:11 PM
aldom92's Avatar
i cleaned the throttle body and connected everything back up. it started fine all day yesterday. i would even turn it off then back on a few times and it would start jus fine. now it doesnt start again. any ideas ? im thinking the fuel pump? any help at all is greatly needed and appreciated.
Old Jun 28, 2009 | 07:01 PM
aldom92's Avatar
i replaced the fuel pump and it was working fine. the only problem now was that rpms wont go above 3000. i changed the distributor cap and rotor, and now it only starts for a second and then turns off. if i disconnect the volume air flow meter, it stays on for like a second longer.
any ideas?
anyone at all?
any thoughts are appreciated
forgot to mention. I also pried open the vloume air flow meter and if i hold the little door open, the runner stays on. maybe a bad vaf?
please someone anyone help!!!
Old Jun 29, 2009 | 01:10 PM
aldom92's Avatar
got another afm and it starts now but it still wont go above 3000 rpms.
help please
Old Jul 12, 2009 | 05:19 PM
rdabook's Avatar
I just became the proud owner of a 1992 pickup that may have the same issue as you. I'm wondering if you have solved your 4runners problem? I would like to fix this myself and would greatly appreciate some advice.
Old Jul 12, 2009 | 08:02 PM
aldom92's Avatar
i changed the fuel pump again and now she runs like a champ. i guess i got a faulty one the first time
Old Jul 17, 2009 | 05:51 PM
aldom92's Avatar
now im having the same problem as the beginning. it doesnt start at all.
havent had much luck receiving help here, but im still hopeful
does anyone have any ideas at all?
Old Jan 2, 2010 | 08:59 PM
qcabra's Avatar
did you ever get it fixed?
If so, what did it? I think I'm having the same problem. Thanks
Old Jan 2, 2010 | 09:03 PM
4Crawler's Avatar
Something to try:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old Jan 3, 2010 | 10:07 AM
aldom92's Avatar
it ended up being the fuel pump. had to replace it like 3 times before i finally got a good one. it drove me insane for a while. turned out it had nothing to do with the sensor. i jus kept getting defective pumps... hope that helps
JF9243176
Oct 8, 2017 04:21 AM
vasinvictor
Jan 20, 2016 12:39 PM
torgeir
Jun 25, 2015 05:26 AM
JF9243176
Jun 24, 2015 04:53 AM
JaredL
Jun 16, 2015 04:47 PM
