Sponsored by: CARiD
Surging RPM with A/C on
Old May 17, 2009 | 07:04 PM
paul91103's Avatar
I have a 85 FJ 60. When I turn on the AC, the engine surges with high and low RPMs. What needs to be adjusted or changed to maintain normal RPM with the AC on?
Thanks.
Paul 91103
Old May 18, 2009 | 08:19 AM
FredTJ's Avatar
Thanks.
Paul 91103
Paul,
It is normal for the rpm to go up when the A/C compressor kicks on and then to drop when the A/C compressor kicks off.
If your A/C system is low on refrigerant then the A/C compressor will cycle off and on and this will cause the engine rpm to go up and down.
This may not be the cause in your case, but it is a very common cause.
I would suggest that you pop the hood and see if the A/C compressor is cycling off and off.
Fred
Ktm526
Oct 7, 2015 05:14 AM
Ricu_air
Sep 21, 2015 08:09 AM
anniesball
10
Sep 15, 2015 05:41 PM
Tacoma1313
Sep 8, 2015 01:27 PM
moparbay
Sep 3, 2015 12:48 PM
