Sponsored by: CARiD
coolant flush - running without antifreeze?
Old May 17, 2009 | 11:56 AM
wilshire's Avatar
The directions on the coolant flush say drain the radiator and add flush + water.
I've drained the radiator and the block, so now there's nothing in the block and the radiator is filled with water and flusher. I put some water in the coolant reservoir too. There's no antifreeze anywhere in the system.
Is it really ok to run it like this?
Old May 17, 2009 | 01:25 PM
Plumbrbob's Avatar
I wouldnt do it for a long time water will corrode your cooling system.
I have done it in a pinch but I typically take it too a lube shop and have them vaccum extract the old and pump in the new, make sure they have the machine. its really cheap under a $100 bucks and you dont have to mess around with coolant and wonder if you got all the water crap out.
Also its spring time so your ok for a little while if it was winter you would not last the night
Old May 17, 2009 | 01:40 PM
jason191918's Avatar
For a flush and refill, it is fine.
Old May 17, 2009 | 03:26 PM
FredTJ's Avatar
If it were winter and he were running the vehicle, then it would last all night no problem.
Water isn't that big of a problem, for a while, and a while means days, not minutes
Fred
Old May 17, 2009 | 04:04 PM
86tuning's Avatar
Yes, the flusher will prevent corrosion, and loosen any deposits. Run it for a day or two, then drain it, refill with water, run it for 20 mins, then drain and refill with 50/50 coolant+water mix.
The main concern with 100% water in an engine is not freezing, but rather, corrosion. Remember how a battery works, different metals + electrolyte. Galvanic corrosion is a serious problem. Driving for as little as 1 week can turn your water in to brown rusty goo.
Old May 17, 2009 | 04:09 PM
annoyingrob's Avatar
I've definitely run too little/no antifreeze in the winter. It's really fun having your cooling system frozen.....not.
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Colington
Mar 8, 2020 09:51 AM
Jonny246
Jul 12, 2015 04:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
