Sponsored by: CARiD
Will a W56-C fit an 88 4runner
Old May 14, 2009 | 10:58 PM
shore.runner's Avatar
Dont worry, I searched.
Unfortunately the answers i came across were sorta open ended..
Like the thread title says, will it? I know the 88 has a w56b that is a top shift, and the C is a forward, but i have no idea what the difference is and if it will bolt on.
For information's sake i drive an 88 4runner, 22re with an automatic i want to swap out and im looking for a parts truck, but dont know if an 89 will be suitable because of this.
Cheers.
Old May 15, 2009 | 05:12 AM
saitotiktmdog's Avatar
http://www.marlincrawler.com/transmi...built-complete
Lets you know what year has what tranny. The G54 58 trannies were for add models i believe. Also I think the difference between w56 a-b-c etc is just the gear ratios and the housings are the same. So I would say yes.
Old May 15, 2009 | 05:42 AM
4Crawler's Avatar
Assuming you are getting the t-case with the tranny, then that combination should work. Only real issue with top vs. fwd. shift is where the shifters come up through the floor. Since you seem to be doing an auto->manual swap, you need to cut holes anyway, so cut the holes where they need to be.
http://www.4x4wire.com/toyota/tech/topshifter/
Old May 15, 2009 | 11:34 PM
alrighty after looking er up sounds all good to me
thanks
Old May 16, 2009 | 12:24 PM
question.
Is the top shift any better than the forward? Im still confused about what the difference is
Old May 16, 2009 | 12:29 PM
4Crawler's Avatar
Originally Posted by shore.runner
question.
No real difference, they both shift the same (2H-4H-4L). On a forward shift case the shift rails come out of the front of the case into the transmission and engage the t-case shifter there. In a top shift case the shift rails are contained inside the case as is the shifter:
Only advantage of a top shift t-case is for use as the rear case in a dual-case setup. The rear case *must* be a top shift case.
kazuya2416
Apr 5, 2024 02:17 AM
crashburnoveride
Jul 10, 2015 06:39 AM
icentropy
Jul 9, 2015 02:12 PM
garagespace
Jul 9, 2015 08:37 AM
wilbertd
Jul 6, 2015 07:39 AM
