Sponsored by: CARiD
removing injectors
Old May 22, 2009 | 12:25 PM
94toy4x4fever's Avatar
removing injectors
Hey guy, I want to take my injectors out and have them sent off to get cleand/rebuilt! How do I go about pulling them out? Any info would be great
Old May 22, 2009 | 01:16 PM
24Runna's Avatar
you have to remove the plenum.
Pretty easy, just takes time.
Remove intake, remove vac lines (LABEL!), depressurize gas tank, undo Cold start fuel line, remove bolts from top, remove support bracket bolt, detach cables from TB, and TA DA fuel injector heaven.
After the plenum is off, you have to remove the fuel rails. Start by detaching fuel lines, front and back, that connect the 2 rails together. Litlle copper crush washers will most likley fall off, make sure to ge new ones from the dealer. Then remove the bolt that olds the fuel line from the tank to the top of the engine. then ou can remove the rails, careful, as fuel may spill out. Always have a few fire extinguishers hanging around.
Then send them off to ge cleaned. In the meantime, now is a prime time to completley clean the TB, and the plenum. Get about 2 cans of carbon cleaner and spray and scrub that carbon away. Mine had oil in it too so it was a PITA, but eventualy got it all out.
Good luck!
Old May 22, 2009 | 01:48 PM
Thanks 24Runna! Thats what I was looking for!
Old May 26, 2009 | 09:31 PM
hey also could bad/clogged injectors cause pinging?
Old May 26, 2009 | 09:53 PM
neilan's Avatar
when my were going bad they didnt cause pinging they just would cycle between way too lean and then the ecu would freak out because of the lean conditio nand dump a ton of fuel creating a very rich condition. All i noticed was bad gas mileage and my exhuast manifold would become glowing red if the engine was under load for very long.
So my answer is mabey, I experienced no ping or symptoms except the ones a described above and my injectors were horrible. Definatly use witchhunter performance for yoru injector cleaning I have tried a few and they definatly are top notch and many other people here can votch for them as a quality service.
Old Apr 28, 2010 | 07:31 AM
zmbombr's Avatar
injectors cleaned? oil in plenum
Hey I am doing a similar job due to a misfire (bad injector), figure having the others cleaned would be prudent. Where did you send yours to be cleaned??
Also the oil in the plenum is normal?
Old Apr 28, 2010 | 07:44 AM
92 TOY's Avatar
witch hunter is someone i've heard alot of good about www.witchhunter.com
supposed to have quick turn-around time too.
oil in the plenum, i don not know anything about.
Old Apr 28, 2010 | 09:39 AM
91_TOYOTA_4x4's Avatar
i thinking need to clean my injectors too but im out of money anybody know howmuch new injectors are or any mods that can be done? i dont want to hijck this thread but it has to do with injectors so... lol
Old Apr 29, 2010 | 02:09 PM
new injectors are alot of $$$! Thats why Im sending mine off!
Old Apr 29, 2010 | 02:15 PM
NwRunner's Avatar
I was looking into getting this done as well and just noticed witchhunter is right down the street from my house, lucky me!
Old Apr 29, 2010 | 02:30 PM
alil2cul4u's Avatar
I found these injectors on amazon for $46 each, I dont think that, they are that expensive! Here is a link these are for the 3.0 Fuel Injector - Amazon
Old Apr 29, 2010 | 04:48 PM
zmbombr's Avatar
Yeah I used this thing called Google, it worked great. I found a place in Torrance, CA, RC Eng. $24 each. Witchhunter I think was $19 and another in NJ, Injector-Rehab (cool mascottts they have) I think $17ea. considering th shipping and delay, I took them RC Engineering and I get them back same or next day.
Reduce, Recylce, Reuse. sweeeet
Old Apr 29, 2010 | 04:59 PM
oh yeah go to toyota and get new injectors and tell me there not spendy! I would never put in new injectors that wernt OEM.
Old Apr 29, 2010 | 05:09 PM
aquaprice's Avatar
I bought a set of new injectors for my 22re. Venom Super Flow Fuel Injectors HP640-177(4) WIth the deal Autoanything.com is doing now they where $216 shipped to my door. I couldn't pass them up with the shape my current ones are in.
Blamalam
Mar 12, 2022 07:34 AM
Doug4320
Mar 24, 2018 10:11 PM
redneck17
Aug 14, 2015 01:22 AM
pyramid
Jul 29, 2015 06:53 AM
Hiluxtrucha
Jul 22, 2015 10:00 AM
