Sponsored by: CARiD
to cut or not to cut?
Old Jun 17, 2009 | 11:53 AM
Hardstripe's Avatar
whats this do, is it safe to cut off? I think it was connected to my trac bar, its leading up to some kind of brake line block
heres a pic before i took off the trac bar
Heres one for a stock 4runner from the other side
Old Jun 17, 2009 | 12:01 PM
scuba's Avatar
Load sensing proportioning valve.
It will send more power to the rear if you have a load in the ass end.
You dont want to cut it off, unless you want to buy a manual proportioning valve
Doesnt look like its connected to the trac bar either..
Old Jun 17, 2009 | 12:15 PM
904_runner's Avatar
What scuba said.
It was connected to the panhard bar from that extension.
You can cut the rod and bungee cord it up. That is what is done often, or so ive seen.
or you can go to summitracing.com and buying a manual proportioning valve.
Old Jun 17, 2009 | 12:19 PM
dropzone's Avatar
Fossilized
if you bungee it up the LSPV will think you have a large load in the rear of the truck and apply more pressure to the rear brakes (i think that is how it works)
-as it moves up it applies allows more brake fluid to move to the back brakes..
Old Jun 17, 2009 | 12:30 PM
Hardstripe's Avatar
If i were to remount it where do you suggest i do it?
Old Jun 17, 2009 | 12:56 PM
4Crawler's Avatar
This is how I did mine:
- http://www.4crawler.com/4x4/4R_suspe...ortioningValve
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
dbollier123
Sep 29, 2015 05:23 PM
