Sponsored by: CARiD
Spacer lift???
Old May 30, 2009 | 07:59 PM
YodasYota's Avatar
Spacer lift???
So I was wondering...
with a lift like these...
-http://www.wheelersoffroad.com/96024rundstrlift.htm (the 1.25in front and rear spacers)
-http://www.xtremeterrain.com/1996-2002toyota4runner4wdand2wd-25liftkit212liftfrontcoilspacers212rearcoilspacers .aspx
Do you need new shocks? or does it space out everything at once? Basically, I want to know if I buy one of these kits if thats all I will need to buy for the lift.
-Thanks in advance!
Old May 30, 2009 | 09:37 PM
scuba's Avatar
I believe this is what you were asking about
To tell you the truth you dont want one of those, dont cheap out on your suspension..
that will ride like ass
BUT, To answer your question, You would need new shocks for the rear, Unless your truck is a street queen..
This is the second one, And while it looks more "complete" its the same thing, It will add preload to your front suspension and will not ride good.
Save up and buy new coils and shocks..
Old May 30, 2009 | 09:59 PM
TOYOTA 1's Avatar
well a spacer lift is not the best way to get lift, it is cheap.
and its not as bad as scoob is describing, i have a spacer lift on my 2000 and i think it still rides ok. though i dont really "wheel" my tacoma all that much. it also made it handle better in the corners (less body roll).
Old Jun 13, 2009 | 08:58 PM
EvergreenToy's Avatar
i considered lifting with spacers simply because i wanted to get rid of the sag and i dont wheel all that much. Instead i purchased some longer procomp coils. They pretty much %$#@ everything up except the look of the runner. It rides awful and makes a terrible sound at highway speeds when i let off the throttle. Im going to search this over but definately be mindful of how little changes affect your rig.
Old Jun 14, 2009 | 07:31 AM
KVRunner's Avatar
If you are going to do any wheeling, definitely go for the new coils.
suppra87
Jul 15, 2021 05:15 PM
1uzRunner
63
Nov 10, 2018 03:58 PM
choppe777
May 16, 2016 08:00 AM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
